Valve Seal Question
Old Jan 24, 2002 | 05:35 PM
JaysZee's Avatar
Car: 91 Z28
Engine: 5.7L
Valve Seal Question
My '91 Z has almost 150,000 miles and I get the puff of smoke on start up from the valve seals. Compression is good and I don't burn any noticable amount of oil between oil changes. I'm planning on rebuilding the L98 this year and will probably go with aftermarket aluminum heads. Since this is the plan, I'm not going to go to the trouble to replace the seals on the stock heads now. Is there any additives I can add to the oil to help? I've heard adding a little ATF will help by making the seals swell. True? Thanks
Old Jan 24, 2002 | 06:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not really. The seals get hard and often crack, at which point no additive is going to make them heal.
Old Jan 24, 2002 | 07:01 PM
sleeper's Avatar
what he said
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Cameeeero
Sep 18, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
