L98 Rebuild question
Old Jul 2, 2025 | 09:09 PM
Rak2rak's Avatar
Change of plans can anyone direct me to were a can find a long block replacement engine for 89 formula l98.
want it to work with the TPI.
would prefer new over remanufactured
looked a ton but not sure what will work with the TPI.
Old Jul 3, 2025 | 06:56 AM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Re: L98 Rebuild question
I would start by checking out all the threads here on this site. There are several including a few I have that outline heads and cams. I rebuilt mine over a year ago. In the end wanted to keep the TPI and I did but then I jump in my 5.3l LS truck with the Borla exhaust and think what could have been. My car runs good but it is likely a 330 rwhp car. Fun but not crazy quick. Don't forget your checkbook, neither will be cheap if done right.
1988 Pontiac Trans Am GTA
  • L98 355
  • Flat top pistons 10:1
  • EGR delete
  • 9th injector delete
  • Lucas #24 injectors
  • 52mm Throttle Body- bored by SPR Performance
  • Custom 3D printed Cold Air Intake- K&N 4730XD filter
  • AS&M Large Tube Runners
  • Ported Plenum- gasket matched
  • Ported Accel/Ligenfelter Intake- gasket matched
  • Comp cam ultra pro magnum roller rockers 1.6:1- CCA-1602-16
  • AFR Enforcer Heads 1006 195cc
  • Crower 00482LM cam- Dur @ .050” Lift: 213°/221° RR: 1.5/1.5 Gross Lift: .505”/.525” LSA: 114° RPM: 1900 to 5900 Redline: 6400
  • Howard roller lifters HRS-91164N
  • Dyno Don Headers and Y-pipe
  • Magnaflow 3” Universal Cat 94109
  • Magnaflow SS Muffler 12267
  • Hayden Rapid Cool Transmission Cooler HDA-687
  • Stellar Auto -Built 700r4 Transmission
  • Hughes 2500 stall
  • Tuned by Tuned Performance
Old Jul 3, 2025 | 06:58 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Cams that "Chop" don't work very well with TPI.
Old Jul 3, 2025 | 07:02 AM
hessm70's Avatar
I second what @Airwolfe said. If you are sticking with TPI then you want a cam made for it. It likely won't "chop" like you think you want. See my thread on cams selection.
Old Jul 4, 2025 | 07:54 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Originally Posted by Rak2rak
...... keep the TPI....sound (chop).....
How do you plan to tune your new combination?
Old Jul 4, 2025 | 09:51 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
  • L98 355
  • EGR delete
  • Hughes 2500 stall
Not to go off topic, but who/where did your 3d printed intake? Got a pic of it? Thank you sir!
Old Jul 4, 2025 | 10:06 AM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
compression makes 'chop'
if you switch to an LS style computer you can tune and modify the engine to run a billion times better than the old 1990s ecus
But ill tell you in the long run, and from personal experience, you'll be better off switching to an LS engine.,
I can post pictures of my L98, 383 FIRST tpi engine sitting in the corner of the shop collecting rat poop., becuase a $1200 4.8/5.3 LS runs circles around it all day long, with the AC on..
If you are close to AZ ill sell it to you.
Old Jul 4, 2025 | 10:20 AM
hessm70's Avatar
My brother and I designed and he printed it on his printer.
Old Jul 4, 2025 | 10:33 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Technically it's valve overlap / reversion that makes chop, but compression does contribute to the race motor sound.
Old Jul 4, 2025 | 03:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
That choppy idle is really nice on a performance machine but hard to get dialed in with your EFI and auto transmission's torque converter. Your basic shortblock is a solid start, your stock heads aren't terrible, but the choke point is the TPI for performance. I'd think about a carb setup with an old school distributor.
Old Jul 4, 2025 | 04:32 PM
Buddy's Avatar
That looks really good! Nice job
Old Jul 6, 2025 | 09:04 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Before you go crazy with a rebuild, make sure the flexplate isn't the issue. I've got a pile of broken ones.
Old Jul 6, 2025 | 10:24 AM
91formula_WS6_5's Avatar
Car: 91 Formula WS6
Engine: L98 5.7
This looks great! You should sell them.
Old Jul 8, 2025 | 06:44 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Old Jul 8, 2025 | 06:57 AM
hessm70's Avatar
Who is this being addressed to? I assume OP but if its me, Tuned Performance is my tuner.
Old Jul 8, 2025 | 12:20 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
The person I originally quoted, who posted this thread.
Old Jul 11, 2025 | 09:21 AM
Rak2rak's Avatar
Thanks will look into that
Old Jul 12, 2025 | 12:52 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Finding new might be a problem. I think all you need is the 350 block that was used for TPI if you have all the other TPI parta. There are tons. The part number is floating around here all over the place. 2 bolt main was used along with roller cam. I'm guessing, if you get the part number, all will bolt right up. I know these guys have them. Here is an example, not sure if this is the correct part # tho.
https://www.mabbcomotors.com/catalog...orged-pistons/
https://www.thirdgen.org/forums/tech...bers-92-a.html
Old Jul 12, 2025 | 01:13 PM
TTOP350's Avatar
Brand new short block
https://sdparts.com/i-24532101-chevr...50-engine.html
Rebuilding your short block would keep your car numbers matching and generally be much cheaper. Have a good machine shop give it a freshen up, you'll be good to go.
Old Jul 12, 2025 | 01:34 PM
LiquidBlue's Avatar
Transmission: MD8
TPI and L98 heads bolt up to that?
Old Jul 12, 2025 | 02:14 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
yikes, I looked into the zz shortblock last year and there were only 2 left in the dealer network. Price shot up 20% too.
Old Jul 12, 2025 | 02:16 PM
why wouldn't it bolt up? Not being snarky, just it's a 350, they're all pretty interchangeable with heads except for gen 2.
Old Jul 12, 2025 | 04:04 PM
TTOP350's Avatar
Yup, just a 87-current sbc and it's what i put in my JY 92 formula
Old Jul 12, 2025 | 04:10 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
^^X2. It's a Gen I SBC.
Old Jul 13, 2025 | 11:02 AM
LiquidBlue's Avatar
Transmission: MD8
Ya I knew you did, but if I recall you had to drill some holes for accessories or something. And of course, your not using the normal TPI system.
Old Jul 13, 2025 | 11:05 AM
LiquidBlue's Avatar
Transmission: MD8
I guess I should define bolt on. Basically transfer everything, all the mounts for a/c, p/s/ all that garbage that would go into a loaded TPI car. Will it all bolt right on? I've read some blocks require a hole to be drilled for accessories. I think some people have had trouble transferring vortec blocks over to a TPI system, EGR or something but maybe that was head related.
Old Jul 13, 2025 | 11:09 AM
TTOP350's Avatar
Just 1 hole in the corvette 113/zz4 head so i can use f-bod bracket.
end of the day, its just a gen 1 roller cam 1piece rear seal sbc
Old Jul 13, 2025 | 01:06 PM
Engine: LT1, L400
^Exactly.
I guess I should define bolt on. Basically transfer everything, all the mounts for a/c, p/s/ all that garbage that would go into a loaded TPI car. Will it all bolt right on? I've read some blocks require a hole to be drilled for accessories. I think some people have had trouble transferring vortec blocks over to a TPI system*, EGR or something but maybe that was head related.
It's HEAD related. Correct. Everything that came off of the car's original short block, will bolt on to the SD/ZZ4 short block...or any Gen I Chev small block, short block. Everything. TTop chose to change the heads -as part of his swap. The head that he chose (the head that comes on a "ZZ4"), required a hole drill & Tap. The head change, not the short block. If one were to swap to 113 heads on to the original short block that came in the car, they would also, have to drill the same hole in the 113 head, for the same reason.
*Vortec swaps: Again, that is a HEAD SWAP issue (not a problem, just something to address), not a block swap issue. You can use a Vortec short block, easy-peasy, under TPI heads, intake, valve covers, etc. and never know that the short block WAS a Vortec short block, b/c you are reusing your not-Vortec heads....which bolt right on to a Vortec block, no drilling or tapping. The Vortec block isn't really much of a "Vortec" block, however, once you take off the Vortec heads. Once the heads are gone, it's basically a typical roller cam, one piece, Gen I short block.
ozzy74
Sep 14, 2024 02:10 PM
Red25thRS
Oct 21, 2004 09:45 PM
ChevTech84
Aug 16, 2003 09:33 PM
