Recommend me an air compressor
Old Sep 30, 2025 | 05:40 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
I don't know for sure yet if I need one. I'm just prepping. But the clutch is smoking when the AC is on (which only stays on for 5 second intervals). It takes some effort to turn it by hand when the engine is off.
Installed is part number 88964849.
Hopefully itll be ok to drive with the AC off. I assume as long as the clutch doesn't engage, I wont have me a fire.
Old Sep 30, 2025 | 09:31 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Recommend me an air compressor
Most compressors will be remanufactured, so brand is largely immaterial.
If the pulley is spinning freely with the AC off, you can just unplug it or leave it off and it wont cause any problems aside from not having AC or defrost. The short cycling is most likely due to the system being low on refrigerant, but if the clutch is smoking it is time for a reppacement. I have never seen a AC compressor cause an engine fire, but there is always a first time. Just replace it and the other related components with a full kit from a reputable supplier, but most compressors will not have a warranty if you install it yourself.
Old Sep 30, 2025 | 10:03 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Is it usually just best to get a completely new unit, or find a replacement clutch/pulley assembly
Old Oct 1, 2025 | 11:43 AM
Beeman's Avatar
Compressors build pressure, with no air flow or an overcharge they can lock up. Have you put a gauge set on it? Is the fan moving air?
Old Oct 1, 2025 | 01:09 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I have had bad luck the the couple of Reman AC compressors's I tried, decades ago.
I have installed 3, "Four Seasons " brand NEW AC compressors and / or compressor Kits, with GREAT results! They even answered my questions, when I telephoned Four Seasons. Rockauto and Amazon both sell them.
I recommend you search craigslist and Facebook Marketplace, for the CORRECT R12 refrigerant. If so, only buy the 12-14 OZ cans of genuine R12/ Dichlorodifluoromethane. The propane sized R12 tanks, can easily be "Faked".
Old Oct 5, 2025 | 09:26 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Yea there's plenty of flow. I had a gauge on it but its been a while and forgot numbers. So today I emptied the system and hooked up a vacuum for a few minutes. It's holding at about -20.
Old Oct 5, 2025 | 09:27 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I might not have made it clear, but its a R134a system.
Old Oct 6, 2025 | 04:23 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
What year is your car? I thought all Third Gen F bodies were R12 AC systems? Unless yours had R134A installed?
Old Oct 6, 2025 | 10:37 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Its a 92. When I bought it with 85k miles, it had 134a already.
Old Oct 6, 2025 | 05:45 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
But now that its empty, i need to find out it's capacity. I assume 30 ounces ?
puma1552
Aug 17, 2010 12:09 PM
MikeT 88IROC350
Nov 11, 2009 06:50 PM
tph87
Apr 5, 2006 11:19 AM
StaticVertigo
Jun 3, 2005 02:20 PM
IROCME
Jul 4, 2002 01:53 PM
