Distributor hold down bolt
Old Dec 6, 2025 | 11:25 AM
M87IrocZ28's Avatar
Car: Red 87 Iroc Z28, LB9, 5 spd
Engine: LB9
Transmission: B/W T5
Axle/Gears: 3.45, performance
I've recently had my engine rebuilt to try and gain a little more performance out of my 305 LB9. I've just checked the based timing and it's set at 0. Stock should be 6 btdc and after mild cam change to Melling 22129 it may need to be 8 or thereabout so I need to adjust the distributor counter clockwise. I can't seem to find the right tool to access the hold down bolt. Sockets are too high in profile and there isn't space to move a wrench in there. Any suggestions on what tool would work here? Appreciate any suggestions.
Old Dec 6, 2025 | 11:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor hold down bolt
9/16 distributor wrench
Old Dec 6, 2025 | 11:35 AM
skinny z's Avatar
x2 to what Tuned said.
I couldn't find a Harbor Freight version but O'Reilly's has this.
https://www.oreillyauto.com/detail/c...zM0Ug0hr9yAfvv
Old Dec 6, 2025 | 12:35 PM
M87IrocZ28's Avatar
Engine: LB9
Thanks for the replies. I've got one of these but there is no space to move side to side as various small hoses are there. I'll try it again though.
Old Dec 6, 2025 | 01:05 PM
That's the EGR solenoid. Just take it loose from its bracket.
Old Dec 6, 2025 | 01:16 PM
M87IrocZ28's Avatar
Engine: LB9
Thanks for this tip, appreciate it.
Old Dec 6, 2025 | 01:31 PM
Vader's Avatar
There are varieties of distributor wrenches, not even counting regular crow's feet. I have three different pattern 9/16", one half-inch although I cannot even recall what uses a 5/16 distributor bolt (maybe a NoPar?) and a "universal" one with ends that interchange and can connect in 90° increments, similar to the Hobo Fright one.
Old Dec 6, 2025 | 02:35 PM
PJD's Avatar
PJD
Car: 89 IROC Z Camaro
Engine: L98 350
Transmission: 700R4 Automatic
Axle/Gears: GM 9 Bolt 3.08 to 1
I've been using a 9/16 "crows foot" on an extension to reach straight down and turn the clamp bolt.
You can see the crowfoot adapter is on the bolt head. should be able to get about a 1/4 turn or so before you have to reposition the crowfoot for another turn.
Old Dec 6, 2025 | 04:46 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 2-piece unit from O'Reilly isn't the best option due to play in between the coupler and end pieces. Scour eBay to find a vintage one.
Old Dec 6, 2025 | 06:20 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
This, with a 6" wobble extension.
kubinusa
May 10, 2012 07:38 PM
Were-zombie
Nov 5, 2007 04:03 PM
MiTHRiL
Sep 29, 2006 01:22 PM
Matt C
Feb 18, 2005 05:24 PM
wasp
Mar 9, 2003 10:01 PM
