Poor Acceleration / Stalling under Load
Old Feb 3, 2026 | 03:22 PM
Ballancers's Avatar
Car: Pontiac Firebird 91’
Engine: 305 TBI
Hey guys,
I’m having a heck of a time trying to diagnose what is going on with my 1991 5.0 TBI Firebird Base Model.
When accelerating under any load the car seems to not fire properly or maybe it’s bogging (I’m not sure) but it accelerates fine in Park and Neutral. It is almost the same feeling as if you were driving a stick shift, and you were in too high of gear for the lower speed you were going - it just seems to not get any acceleration / power.
If you press and hold the accelerator for too long, it will keep bogging or whatever it is doing, and it will eventually stall out.
The only code I am getting is GM 12.
I have replaced the following to try and remedy this problem but none have seemed to work.
Rebuilt and cleaned entire TBI
New AC Delco fuel injectors
MAF Sensor
Throttle Position Sensor
IAC valve
EGR Valve
EGR Solenoid
Inner Air Temp sensor (air charge)
Engine Temp Sensor
Fan Switch
02 sensor
thermostat
Distributor
Spark plugs and wires
All New fuel lines, fuel filter and upgraded pump.
I have replaced all vacuum lines hooked to TBI and EGR
Installed new fuel line with an external regulator that regulates pressure at 13-14 psi (even under load) I’m getting plenty of fuel. I Platted off the internal fuel regulator (it was doing this problem before I messed with the fuel regulator)
The only solenoid I haven’t replaced is the charcoal purge canister.
What in the world am I missing here?
Someone mentioned the torque converter… why would this affect acceleration under load?
Any help would be much appreciated,
Comicazy
Jun 26, 2015 07:01 AM
TipTricky
Jul 2, 2014 10:02 PM
Mitchemracing4
Dec 6, 2012 10:31 PM
Blue_Thunder_89
Dec 6, 2012 02:55 PM
Formula_Ranger
Aug 16, 2005 10:13 PM
