Pulley Noise????
Pulley Noise????
Today I went out to start my 90 Trans Am 350 TPI and it started up just fine. After about 2 minutes of running I started hearing a loud whirling noise almost like a bad pulley???? Assuming it was the alternator pulley I grabbed a screwdriver and put the metal end on the alternator and the other end to my ear but the noise wasn’t coming from there. As I was looking around the engine bay trying to see where the noise was coming from it suddenly stopped? I let it run for a while but the noise didn’t come back. I turned the car off and started it again and no whirling noise???? Any ideas? I did change the AC compressor last summer but didn’t have any issues? Thanks in advance.
Re: Pulley Noise????
It's the quote below the post itself. Might not appear if you're using just a phone. It reads:
Numquam ponenda est pluralitas sine necessitate.
— William of Ockham, c. 1330 AD, from Quaestiones et decisiones in quattuor libros Sententiarum Petri Lombardi
Roughly paraphrased into modern English, and applied to figuring out what's wrong with your car:
The simplest explanation that fits all the facts is most likely to be the right one.
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
Carquest Premium 2 Pole Radiator Fan Motor Part # 35656 (made in Canada)
(61 reviews)
Spoiler
limited lifetime replacement
$44.99
As low as $35.99 (20%Off)
quisterio
Dec 21, 2012 05:25 PM
