changed thermostat, now erratic idle problems and a few *other* things
Old Jan 26, 2002 | 10:41 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
o.k., my z was getting poor gas mileage, about 9 to 10 miles a gallon. my temp gauge is pegged and my oil gauge is reading zero. i also noticed that my car was running a little hot for it being the winter so i decided to change my thermostat. i went with a 180 stat and also got the necessary water outlet gasket. i took the old rtv and gasket off and installed the new one. as i was tightening the bolts down, i noticed the drivers side bolt was going in a little funny, i took it out and put it back in, same thing. i tightened it down and thought no worries. i then figured that i needed to adjust my IAB valve on my carb since i was running rich. i drilled out the rivets on the little airhorn thing and pulled off the cover. i start my car and it idled like complete crap. in park it idled at 500 rpm and was really rough. i tinkered with the screw (3 turns from all the way down is the base setting) and it idled fine when the screw was all the way down. i checked my vacuum lines and adjusted my timing, now my idle goes from 600 to 1100 in park. something in the back of my mind is tellin me that my distributor is to blame, or even my msd since i noticed somewhat of a funny idle before i started changing things. i took my car out for a spin and when it holds a certain rpm (like 2000, or 1500) it will sorta sputter out. when i floor it the car doesnt pull like it used to. im almost stuck on this problem so i come to you guys hoping for a fix-
Old Jan 27, 2002 | 12:15 AM
Engine: LB9
Axle/Gears: 3:43
well it seems the problem has worsened, my car doesnt even want to idle and when i tried to go somewhere i got as far as the street and then it died on me, its idling way way too low, if anyone has any advice that would be greatly appreciated!
Old Jan 27, 2002 | 12:38 AM
Xenodrgn's Avatar
F'ed up your CTS?
Old Jan 27, 2002 | 01:35 AM
Engine: LB9
Axle/Gears: 3:43
the wierd thing about the cts, i replaced both the pigtail connecting harness, and the actual cts in the coolant crossover, to go along with the cts in the cylinder head. the sender in the head however, never worked quite right, it reads the temp about 60 degrees too much. the dumb air tubes are in the way and i cannot seem to get a wrench on it and put the old one back in its place.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Bob88GTA
Aug 18, 2015 03:31 PM
gta power
Aug 13, 2015 06:15 AM
matthew911
Aug 12, 2015 09:38 AM
