Removing AC
Old Jan 28, 2002 | 10:09 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Removing AC
Ok, I have the compressor (sp?) out and everything except for the black casing. Can I remove this and still keep the heater? I am trying to get as much stuff out of the engine as possible. Also will the defroster still work??
Old Jan 28, 2002 | 08:26 PM
Camrs89's Avatar
anyone????
Old Jan 28, 2002 | 08:43 PM
Chevy83Z28's Avatar
I'm wondering the same thing. Would make a perfect spot for MSD ignition box ... thinking about going to a junkyard, and taking that piece off a non-ac car, to retain use of the heater/defroster. I think the heater core is on the other side of the box though, with the firewall sandwhiched between (so take the box off, and don't be surprised if the heater core falls down in the passenger compartment.) Not 100% sure though, maybe someone can answer?
Old Jan 28, 2002 | 10:19 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I took my ac out a while ago so heres the deal.
You can't just tear that box out. You have to cut it. The ac condenser is inside the right part by the canister. Just tear the right part of the box out and all the ac crap will come out. The fan is just to the left so you will have to make a new enclosed wall for the fan to blow into the heater core. The core is just inside the firewall and will not fall out. My defroster is the only thing that still works. But that is probably a vac leak. Good luck
Old Jan 28, 2002 | 11:04 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I removed the windshield washer fluid bottle and mounted my MSD right there. My friend mounted his on the fender well just next to the AC stuff. Just some ideas.
Old Jan 29, 2002 | 12:32 PM
Chevy83Z28's Avatar
Thanks for the ideas, 86TpiTransAm. I was also considering mounting it somehow on the shock tower (I'd like to keep the washer fluid... car is an everyday driver .) If you go to the junkyard and find the box off a non-ac car though, won't that have the same effect as No4NJunk suggestions? It should be cheap and would look more clean I'm thinking...
Old Jan 30, 2002 | 12:51 PM
Camrs89's Avatar
still wondering...can i remove that black case and still retain the defroster and heater???
Old Jan 30, 2002 | 01:36 PM
No4NJunk's Avatar
No. If you remove the whole black peice the blower fan will just blow into the engine compartment and not into the core.
Old Feb 2, 2002 | 07:08 PM
DM91RS's Avatar
Car: 91 RS
Is this what you had in mind?
Old Feb 2, 2002 | 07:14 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Your best bet would be to go your nearest G.M. parts counter and see if they offer a heater case for a car without A.C.. The car in the picture above looks clean and probably is a factory piece. Another option would be to troll the bone-yards for a car with out A.C. and ****** some parts off of it.
Good luck.
Old Feb 2, 2002 | 07:28 PM
Chronos_Titan's Avatar
Good luck finding a non-AC car. I have only seen a couple of them. Your best bet is V-6 cars. Most every V-8 had AC. I would just say to the hell with the Junkyards and go straight to my favorite Chevy or Pontiac dealer and ask for a non AC fan housing. That is just my .02$.
By the way i drove my car with a big hole in the Firewall there for a while and it is not bad in good weather, but when it starts raining i suggest keeping paper towels handy.
Old Feb 2, 2002 | 08:05 PM
DM91RS's Avatar
Car: 91 RS
Guys would you believe that the non-a/c heater box in the photo was made by reworking the stock a/c unit? Look close, it's not the factory non-a/c box which by the way from what I understand is no longer available. That is one reason that I reworked my stock unit after planning an in car head change and seeing how much in the way the a/c box was.(I had already taken the rest of the a/c out)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
