Brake lines
Old Jan 28, 2002 | 06:50 PM
XChris1632X's Avatar
Car: 83 Z-28
Engine: LG4 305
Brake lines
Id like to know where the vacuum tube is that goes to the brake booster. if anyone has a diagram pleeze help
Old Jan 28, 2002 | 07:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Scrap my old post I read your sig.
Since you have a holley your going to have to tie your booster in a manifold vac source. Right behind the carb there is a hole on the manifold (99% of manifolds) that you can tie into to opperate power brakes. On the stock intake one of there lines goes to climate controll to oprate the gates in the heater there should be 2 sources on the fitting the other source went to a canister use that for your brakes.
SSC
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
