Car misses, stalls occaisionally
Old Jan 29, 2002 | 04:41 AM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
My car will develope a miss after it warms up, on occaision it will stall but starts immediatly without problem. It will also stall occaisionally if I stop and change gears(park or reverse). The parts I have replaced are
New injectors
New cap,rotor wires
Ner egr valve
New egr solenoid
New Fuel filter
New coil
New K&N air filters
A neighbour who is a mechanic thinks it might be the ignition module. The mechanic who I've taken the car to(diagnosed the bad injectors) says that Ignition modules are like light bulbs, when they go your car won't start. I don't want to waste money on any more parts to fix this problem, please help..
Old Jan 29, 2002 | 06:12 AM
KeithO's Avatar
I think I had a similar problem about a year ago.
When the engine heat soaked (2-4 heating cycles up to 220 and back to 160), the car would stall usually at low rpms, like when stopping at a stop light. I changed the O2 sensor (didn't fix), plug wires (didn't fix), then I started dumping BG injector cleaner in even more often then recommended. It went away. I have no idea if it was a dirty injector or something else...
Old Jan 29, 2002 | 01:13 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I don't see new plugs on your list........
Old Jan 29, 2002 | 02:55 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, what about the plugs? Any ways, from what I've seen it could be the module. Another thing, do you have an after market chip in it? I had a similar problem when I bought mine and after going through the same things I figured it had to be a bad ECM. Took it appart and found an ACS(I think) plugged in. Removed it and the car never had a problem after that. POS chips!
Old Jan 30, 2002 | 04:03 AM
Engine: LB9
THe plugs are new bosche platinums, the e prom is factory. Do you think the IAC could be the problem?
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wade787b
Sep 29, 2015 01:15 PM
MY87LT
Aug 17, 2015 08:43 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Exxon Limited
Aug 9, 2015 08:13 PM
