How fast?
Old Feb 2, 2002 | 12:25 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How fast?
I was just wondering if anybody knows how fast a Mazda Rx-7 idles and its red line. I'm talking about the rotary Wankel engine, with/without turbos.
Old Feb 2, 2002 | 01:49 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I heard they whind?
Old Feb 2, 2002 | 09:04 AM
GreenProStreet's Avatar
Rx-7s are designed for Rotary engines, like a Z28 is for a small block. For one a Rx-7 is much lighter than a Z28, and the rotary engine has little torque compared to the V8 you have in there. The transmission is geared for high revs.
You would have to 'reinvent the wheel' as it were, or at least your Camaro. And you would have a car that would perform worse than if you would have invested it in your V8.
The Miller Cycle engine is a better (and cooler) idea!
Old Feb 2, 2002 | 09:06 AM
Plus, the first generations suck gas, and fail emmisions like a mother f***er!!!!
Old Feb 2, 2002 | 09:29 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Your best bet would be to PM rx7speed or IM him rx87speed. I would think their redline is around 7k. But those motors are known to have a short life if I remember correctly.
Old Feb 2, 2002 | 11:31 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
send this guy mail -- he has been posting here lately
https://www.thirdgen.org/techbb2/mem...fo&userid=8999
Oh,, i see mark listed him.
sorry.. not trying to rack up points.
Old Mar 4, 2002 | 12:36 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
hehe I'm here
ok as far as putting a wankel in your car....forget it.
yeah you can do it but it would not be the greatest thing unless you went with a peripheral port on the motor but from what I understand that would not put up any power till about 3000 rpms and it would not have a lot of power before that though you can rev it till about 10-12k rpms and need to do a lot of stuff to your car to handle that high of a rpm range
the only other way would be to put a turbo on there
since these motors are so small you shouldn't have too hard of a time to put a turbo in there
thought you would still need to do a lot of work to get a rotary in there
now if yo uare serious about the idea I would go for a 20b
they put out prolly just as much torque as your V8's do and have a much wider powerband. though cost would be a big thing there since they are imported from japan
I have hit 9k or so I am guessing on mine
stock redline is 7k and tach only hits 8k but I know when I let off the gas it took amoment or two for the tach to start reading anything other then 8k
I shift most the time at 7600 though cause after that I will have a loss of power b/c of stock port size
the idle should be at 750 rpms just like a normal car
as far as engine life most of them are false, or come b/c these cars are a little touchy on how you take care of them. if you take care of them they will last just as long if not longer then a piston motor. you dont take care of them though then they last a lot shorter ofa time then a piston motor
and mark it's rxspeed87 for aim
they are a cool motor though
if you want my write up on them
https://www.thirdgen.org/techbb2/sho...&highlight=rx7
and there is another one in the ontario board
if you need more just ask away
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
