Different height distrib. from 305 to 350?
Old Feb 3, 2002 | 10:06 PM
GlenYappa's Avatar
I am building a supercharged 350 for my '84Z. I was test fitting my old distributor (off the original 305 H.O.) and realized it does not sit all the way down on the intake manifold. I would say it is a good inch too tall. If it did sit on the intake manifold it appears it would be a loose fit. I was under the assumption that the 305 and 350 distrib. are the same. What is the deal? I have to pass emissions so I need to use an HEI distrib. that works with my computer. According to MSD I have to use a remanufactured one because nobody makes an aftermarket HEI for my year. Do I just need to talk to Holley about their supercharger intake manifold(not again please!)? Any help will be greatly appreciated.
Thanks,
glen
No, I am not going to use this air cleaner when it's finished.
Old Feb 3, 2002 | 10:17 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The distributors are the same. Is it not engaging the oil pump right? Have you tried turning the motor over by hand while wiggling the distributor? Usually that'll make it drop in the rest of the way.
Old Feb 3, 2002 | 10:31 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Yeah, it sounds like its not engaging the oil pump shaft. You need to line up the shaft with where the tang on the dis. will meet it while you drop it in.
Just use a long flathead screwdriver to do this.
Old Feb 4, 2002 | 08:51 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Thats what I was thinking too. By the way, nice lookin motor. Almost be a shame to start up and drive....get it all dirty and everything
Old Feb 4, 2002 | 10:04 AM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
dear glenn,
i've used my old 305 distributor on my 350 and fits like mama and papa. just be patient, it'll fit the same.
by the way are you planning to go supersonic with that???
you have a mean MF'g. muswang killing engine...enjoy it.
Fernando.:hail:
Old Feb 4, 2002 | 11:25 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Geesh, even his engine stand is better looking than mine
Old Feb 4, 2002 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
FWIW, a 305 distributor is the same height as a 396/402/427/454/502 distributor. How 'bout them apples?
Yep, it's sitting on top of the oil pump shaft rather than in the slot.
Damon'll love the carb...
customblackbird
Aug 15, 2021 10:16 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
st.evel07
Aug 13, 2015 06:15 PM
