header leaks (I think)
Old Feb 3, 2002 | 06:20 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I just got done replacing the header gaskets with those expensive copper ones and now it leaks worse than before. I got the bolts cranked down but it still leaks. Ihave multipull(sp?) leaks and the largest is coming from the back of the drivers side cylender bank I'm out of Ideas. Oh by the way I got a cross-threaded bolt in the drivers side cylender bank second from the front- (It's not leaking from around it yet) dose anyone know how to fix it without taking the head off or should I just leave it because that area is not leaking?
Old Feb 3, 2002 | 07:29 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
mixed feelings about copper...
some say its the best ever
some say they suck
i say they suck, my copper collector gaskets are leaking horrably.
"They" say you should not "CRANK DOWN" on the copper gaskets, they only need a little tightness, overtightening can cause warpage which causes leaks.
good luck...
Old Feb 4, 2002 | 12:01 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I have the same feelings about copper. It sounds like you dident get all the old gasket off and thats were the problem is. I like the flow tech aluminum gaskets, there real thick and seal quite well also there the same price as the copper. Too bad the same cannot be said for thier collector gaskets POS's!
I would try cleaning the heads and headder flanges up a bit more and put a helicoil in the cross threaded hole. If the headders arent all bolted down it increases the chance of warpage and more leaks. If it wasent for the leaks I would love headders, but they all leak and I hate them and wish I never installed em.
SSC
Old Feb 4, 2002 | 01:44 AM
Engine: 383
I've had it with these exauast leaks- theres a muffler place down the road from the base and I'm taking my tax refund and having them fix it with a warinte and put true duals with 2 3/4 inch pipe back to a single 2 in 2 out muffler with no cats (I'v been told if you slip them some xtra money they will do that)
Old Feb 4, 2002 | 12:03 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
dont exhaust leaks sound badass but they are really bad?
Old Feb 4, 2002 | 02:15 PM
Xenodrgn's Avatar
Sounds badass?
Depends.. big ones mneh... ... little ones suck!
TSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
All down the road... and all you want to do is shoot yourself because you can't find the leaks, your power suffers and it's annoying and embarassing...
I speak from experience...
z 28 jari
Sep 14, 2021 10:03 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
