anyway to get extremly cheap power???
Old Feb 4, 2002 | 09:01 PM
Blade69's Avatar
is there anything i can do to my 84 with a 71 350 to get power as cheaply as possible? Is there any tricks of the trade secrets like( just made this one up) clean out your air hoses for an extra .1 in the quater mile. ANYTHING!!!!!!!
Old Feb 4, 2002 | 09:12 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
need some more info on the vehicle and we may be able to help.
Old Feb 4, 2002 | 09:20 PM
silverstreakII's Avatar
clean the carb, run no air cleaner, high octane gas with timing bumped up, just a few, not much for free though.
Old Feb 4, 2002 | 11:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Cheap? Strip everything you don't need out of the car. A 170hp 3000 pound car is quicker than a 170hp 3500 pound car. Doesn't cost anything to take stuff out.
Power costs money. "Low buck" and "add-ons" do very little to actually making real improvements. Putting on that K&N filter gives 15 HP? Maybe of your old paper filter was plugged solid.
Cam, intake and heads are the best ways to make power (other than NOS). Everything else just enhances what's already available.
Old Feb 5, 2002 | 02:45 AM
Jza's Avatar
Jza
A port and polish job on the intake and heads are a good, cheap boost, costing only the abrasives kit ($30) and a goot bit of work.
Old Feb 5, 2002 | 01:08 PM
87formula's Avatar
The best thing you can do, it isn't the cheapest though is to lighten up the rotating assembly, this means, crack, rods, pistons, clutch or torque convertor, transmission rotating assembly, driveshaft, rear end, anything that rotates. Next lose any and all weight possible on the car(the same for you, LOL).
I have more tricks but I use them alot in the series I race in so I don't want to disclose them.
Old Feb 5, 2002 | 03:21 PM
SoCo80p's Avatar
going fast and cheap are forsure 2 words that dont work togeather if your trying to build a car.
Old Feb 5, 2002 | 03:28 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
What Steve said.
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
sailtexas186548
Aug 24, 2015 10:11 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
