pulling only 6" of vacuum , no visible leaks, where to check?
Old Feb 5, 2002 | 12:44 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
like the topic says at idle im only pulling six inches of vacuum and my lines look good and solid, the connections are all good as well. could i be losing all the vacuum if my carb is shot? could i be losing vacuum if something was stuffed up my muffler? my heater vents are no longer working, could i have snapped a line somewhere going to my heater? im stuck....
Old Feb 5, 2002 | 12:59 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
get a can of carb-cleaner and spray it round the base of carb
when idling..
check rockers for proper adjustment
good general tune up recently?
Old Feb 5, 2002 | 04:59 PM
JAY87GTA's Avatar
Yeah, a good tune up and what is your idle like? Does it surge or real rough, and whats the RPM at?
Old Feb 5, 2002 | 05:58 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
get a propane torch, open the valve (DON'T LIGHT IT), move the tip around your vacuum lines and fittings, when the engine sounds different you've found where a hole is sucking propane in.
Old Feb 5, 2002 | 07:59 PM
Engine: LB9
Axle/Gears: 3:43
i just got done changing the plugs (which i thought would fix it) and it didnt do a thing. the cap, rotor and wires have about 3k on them. timing is at 0 degrees. i even bought a new coil and msd ignition, and i went back to my old ignition and coil and still nothing. the idle jumps around alot from 500 to 1k, and the wierd thing is it'll sit there for a few seconds, drop down and sit there for a while, then go back up. its wierd.
Old Feb 5, 2002 | 08:52 PM
Xenodrgn's Avatar
0 degrees?
Dial in some advance... anywhere from 4-12 degrees... advance till it pings, back off a bit and use good gas... you'll be fine...
FP good?
Old Feb 5, 2002 | 09:08 PM
Engine: LB9
Axle/Gears: 3:43
i have no clue as far as fuel pressure, as i havent put a gauge on it yet, but advancing my timing didnt seem to make much of a difference, it just made my car idle higher. i cant figure out why my idle jumps around like it does. this car is making me angry im about to smoke it like a joint at nate newtons house. well maybe not but im sure you guys know what its like when your car sits and goes nowhere forever.
Old Feb 5, 2002 | 09:50 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
What should the vacume be at idel??
Old Feb 6, 2002 | 12:36 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
A steady 17-21 in-Hg. No fluctuating.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
