modifying heads for new springs
Old Feb 5, 2002 | 06:47 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
When I get my engine I'll be putting the lt4 hot cam in it, in order to put the stronger springs on what needs to be done to the heads? Does it need to go to a shop or can i do it myself? With the new springs will I need new retainers, valve locks, etc.?
Old Feb 5, 2002 | 06:50 PM
SoCo80p's Avatar
that cam isnt too wild big so the retainers and such should be OK but there pretty cheap so its not a bad idea to get new ones. you can do the springs yourself, its not too difficult, if you have a good aircompressor you can do the swap without taking the heads off
Old Feb 5, 2002 | 06:55 PM
Car: '87 Camaro LT
Engine: 355 L98
do the valve seats need to be milled wider or anything like that?
Old Feb 5, 2002 | 07:03 PM
SoCo80p's Avatar
thats only when you go with a roller cam
Old Feb 5, 2002 | 07:07 PM
Car: '87 Camaro LT
Engine: 355 L98
so if i start with a roller engine and put in a roller cam I just need the springs then, right?
Old Feb 5, 2002 | 09:05 PM
ede's Avatar
ede
match the springs to the cam, if they're larger diameter than stock you'll have to make the spring seats larger, job for machine shop. if you're running bigger lift maybe need to mill the tops of the valve guides. you need screw in studs with any lift over .475 so thats more milling, plus tapping holes. trash the stock retainer/rotator assembly and run after market retainers.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
