How to convert to 383 stroker
Old Feb 13, 2002 | 07:51 PM
89blackbird's Avatar
I just took my engine apart thr other night to find my crank has been turned. The engine had a light rod knock before I took it apart. At this time I may change over to a stroker. Other than changing the rods,crank and pistons what other machine work do I need? I will be running 58cc heads and zz4 cam. I would buy a rotating assembly with new damper and flex plate. Thanks
Old Feb 14, 2002 | 06:35 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
383 cost
Bill mitchell at hardcore racing. Has a nice 383 set. Last time I checked it was all stell rods and crank, forged pistons, internally balanced already all for $1800 which is a damn good price for a balanced all steel assembly. Hope this helps, that is the best kit i've found.
Old Feb 14, 2002 | 05:18 PM
Thanks but I would like to keep my block. I have found Rotating assemblies for around 800.00. I really don't fell I need a forged crank . I will never push the engine past 5500 rpms (I hope) What mods have to be done to the block???
Old Feb 14, 2002 | 07:43 PM
FstBrd6point3's Avatar
I just found out putting mine in the car that you need the starter from a 400. . looks like I have a few hours of work to do still, but I am not going to bed until I can start it up.
Old Feb 14, 2002 | 07:58 PM
ronterry's Avatar
Car: '94 Corvette
I think you'll need some mild machining done on the block so the rod bolts will clear. The piston need to have the right pin height if you use 400 rods or they will hit the counter wieght on the crank. That's my experience at least, from about 1990
Also need a balancer, and flexplate from a 400CIN. However, I heard about an internaly balanced setups, but it will probably cost you more.
Ron
Stick with a High compression 350, or go with a 400 !!!!!
Old Feb 15, 2002 | 03:32 AM
Jza's Avatar
Jza
You do keep your block with the package he was talking about. That's the one that I will be getting myself.
Old Feb 15, 2002 | 05:36 AM
What has to be done to the block?????????????
Old Feb 15, 2002 | 07:30 AM
ronterry's Avatar
Car: '94 Corvette
When I had mine done they needed to groove out a few slots for the rod bolts to clear in there rotation.
It's hard to explain, you would have to see it...
Maybe someone has a PIC ???
Ron
Old Feb 15, 2002 | 08:13 AM
Chronos_Titan's Avatar
The block has to be ground down around where the oil pan bolts onto it. This has to be done to clear the rod bolts. If you dont do this you will whack your rods into the block. Minimum .050 clearance. Also check the clearance between rods bolts and cam. I had to grind mine down to clear.
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
IROCZ1989
Sep 4, 2015 11:54 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
