What head gaskets with o-rings ?
Old Feb 14, 2002 | 02:20 PM
Blackened's Avatar
I've got a 400 block that was already o-ringed by the previous owner. The machine shop is telling me that the only gaskets that will now work with this setup are copper head gaskets. From what I've seen on this board these gaskets will eventually leak. Can a similar FelPro gakets be used with no problems ? Or any other gasket that will be somewhat more reliable ? Thanx
Old Feb 14, 2002 | 08:23 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll need a copper gasket for it to seal properly.
Old Feb 14, 2002 | 08:37 PM
ronterry's Avatar
Car: '94 Corvette
All Baby, That setup is ready for a super high compression setup !
I have a set of SCE coppers hanging in my garage.
Head over to http://www.scegaskets.com/ , and get you set.
Weather you can run them without, I don't know ?
Copper gaskets, and copper spray, it shouldn't leak that bad.
Ron
Old Feb 14, 2002 | 11:28 PM
Blackened's Avatar
Dammit.. I was hoping I can get away with NOT using them. I heard they suck on the street as far as reliabilty goes. Is that true ? Taking off the heads and replacing gaskets is not fun.
Old Feb 14, 2002 | 11:45 PM
ronterry's Avatar
Car: '94 Corvette
I'm woundering if you could get away with using some Fel-Pro 1010 ?
They are a composite head gasket with a copper core instead of steel. Normaly used with Aluminum Heads.
I would question the reliabilty factor ? I don't know, so I would contact SCE or other OEM'er that make copper head gaskets.
Ron
Old Feb 15, 2002 | 03:10 AM
Blackened's Avatar
When I bought this block it had heads on it. And guess what... 1010 felpro gaskets were used. I dont know if I should contact SCE and ask them if I can use a competitor's gasket. I have a feeling they'll give me a biased opinion. LOL
Old Feb 15, 2002 | 03:46 AM
ronterry's Avatar
Car: '94 Corvette
Cool, the only down side is the 1010's cost about 30 bucks each.
I use them myself.
Ron
Old Feb 15, 2002 | 03:54 AM
Blackened's Avatar
Niiiice! I'm thinking I could reuse the 1010's. The heads were torqued to the block but it was never run so the gaskets still look brand new. They ARE copper gaskets after all, just with a coating added on. Maybe I'll call FelPro and ask them... hmmm....
Old Feb 18, 2002 | 01:51 PM
Blackened's Avatar
Any new ideas... hopefully from people that have "been there and done that" ? THanx
Old Feb 25, 2002 | 04:54 AM
Blackened's Avatar
How about 1014's ? Btt
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
