Oil pressure gauge shoots all the way up WTHell?
Old Feb 14, 2002 | 04:34 PM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
My oil pressure gauge goes all the way up (to that little black pin and stops) when the car is in Part Throttle or WOT. When i let the foot of the gas the gauge drops to where it should be. It works fine when i am accelerating slowely.
WTHell? Should I worry?
What can cause this?
It happened after I got an oil change at Walmart. I am using same 5W30 Castrol all the time.
Any suggestions?
Old Feb 14, 2002 | 04:54 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Mine is currently doing the same thing. I've been told the oil pressure sending unit is on the way out and should be replaced.
Old Feb 14, 2002 | 06:23 PM
blue91rs's Avatar
change the filter that they put on there, and check the oil level. Did it happen immediatly after you took it there?
Old Feb 14, 2002 | 06:33 PM
88camaro's Avatar
mine actually does the same thing , how much are these oil sending units , and how accecable are they
Old Feb 14, 2002 | 06:41 PM
Metalifann's Avatar
Mine has always done that. My sending unit is only about 3 months old. The old one did the same thing. When the old one went out, the pressure on the gauge showed 0.
I always just figured that the gauge was about as accurate as our great gas gauges. I use 5W-30 mobile one and a pure one filter. My motor has about 115k on it. Its always ran great so I wouldn't worry about it.
Old Feb 14, 2002 | 06:43 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The oil sending units in our cars are notorious for being inaccurate. Mine had an aftermarket one installed before I got it.
Old Feb 15, 2002 | 08:26 PM
88camaro's Avatar
how much do these things go for anyway , and yeah , i can kinda relate to the fuel gauga aswell , uphill i have a full tank , downhill if i hit the brake , im almost empty ,lol . so yeah , how much do the oild sending units go for
Old Feb 15, 2002 | 08:30 PM
Car: 99 Formula
Axle/Gears: 342
I would think around $30. Check www.summitracing.com or www.jegs.com
Old Feb 15, 2002 | 08:44 PM
GreenProStreet's Avatar
Doesn't have much to do with this topic, but DONT go to a high volume, high pressure oil pump. A stocker with a 69 Z28 will satisfy even a 700 hp, 7000 prm engine, and any thing more can be fixed with a big block pump.
Just something to keep in mind!
Old Feb 15, 2002 | 08:51 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Having your Oil Gauge 'pegged high' is either: 1) Oil sending unit, 2) Shorted wire from sending unit to gauge or 3) Bad gauge. In that order.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
