160 thermostat
Old Feb 15, 2002 | 05:34 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
160 thermostat
should i get a 160 thermostat or just get the stock one. does it do anything. can i get it at a local parts store. thanks alot.
Old Feb 15, 2002 | 05:45 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Living in NJ, I wouldn't get a 160* stat until the weather gets a little warmer so you'll have warmer heat. You can get it at the local auto store.
Old Feb 15, 2002 | 05:54 PM
89BlueTA's Avatar
I have never had a problem with heat, with my 160 stat, and I live in michigan, though a good compromise is the 180. That is what I run right now.
nick
Old Feb 15, 2002 | 06:07 PM
Car: 84 camaro Z28
Engine: 434sbc
i don't drive much in the winter with the camaro
Old Feb 15, 2002 | 06:20 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd go with the 160 t stat which you can buy at your local parts store, but only if your planning to bump your timing up some. i'd advance it 3 to 4 degrees over stock.
Old Feb 15, 2002 | 11:46 PM
dps8315's Avatar
I thought I read somewhere that dropping your tstat rating like that can cause a problem with your ECM... is that related to the control of timing?
or was it just really late when I read that and this is a stupid question?
James
Old Feb 16, 2002 | 12:44 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I would recommend going with the 160 stat if you're planning on running a Thermo chip with low temp stats. A low temp stat can play some nasty tricks on a stock chip.
Old Feb 16, 2002 | 01:02 AM
TBI305Camaro's Avatar
with a 160 degree stat and the stock chip it pretty much made my car run in warmup mod ALL the time which was good in a way but killed gas at the same time. ran rough like when you first start it up but im not worried about that. if i go carb (i know i know but ive been toying with the idea and when i switch cams and heads this summer itll be much easier to tune) ill be running a 160 for sure since the ECM will no longer be in play id like to hit high 13s this summer all motor and maybe high 12s with alittle juice. well have to wait and see what happens i thought about switching motors but if i can hit 12's for less than 3k ill be happy plus it would be putting 5.0 mustangs to shame and they could use the old excuse "well its because you have a 350 you have 48 more cubic inches than me"
Old Feb 16, 2002 | 11:49 AM
dps8315's Avatar
My car overheating :)
I'm actually having a problem with my car running too hot, as high as 220, even with the fan on. I know I'm losing a bit of coolant so that could definately be part of the problem, but I've got a recently installed 195* stat and even before I started having the cooling problem, the temp gauge would rocket up to about 220 before thinking about cooling off.
Does anyone know why lowering the tstat will affect your car so poorly?
I didn't plan on dropping to a 160* stat anyway, but I was hoping that I could go with something like a 180* without having any problems.
James
Old Feb 16, 2002 | 11:50 AM
Car: 84 camaro Z28
Engine: 434sbc
thanks alot. i went with the original 195 thermostat and put it in this morning. i don't want any problems.
Old Feb 16, 2002 | 12:33 PM
89BlueTA's Avatar
dps8315-
When you put in a 160 stat, sometimes the car will not go into closed loop operation, it will stay open. So your gas mileage will suffer, the stock computer will be trying to warm the car up.
nick
Old Feb 16, 2002 | 01:42 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Originally posted by 89BlueTA
dps8315-
nick
Yeap. That happens to me. Time for a 180 this summer.
sheachopper
Jul 31, 2019 11:27 AM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BWilcox
Sep 20, 2015 12:19 PM
