What size and type of battery?
Old Feb 16, 2002 | 08:29 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I need a new battery to replace the old Die hard.
what I need to know is what is the stock size battery in the 88 firebird?
and if you want to venture an opinion -- what battery do you like?
Thanks for the reps.
Old Feb 16, 2002 | 10:37 PM
Vader's Avatar
88,
I've had good luck with the Delco 75-6YR-800CA. Any group 75 with a good cold crank rating should be sufficient. I like the Delcos since they have the hydrometer eye built in, and only have side terminals. Those "dual-terminal" batteries have plates that are not optimized for power transmission to the side terminals, and tend to have a little less capacity.
That's not to mention the potential problems of a couple of extra hot terminals hanging out above the battery in an already tight area. The Delcos are getting a little harder to find, but some better auto parts suppliers still offer them. There is also an Eveready battery that has a good rating (900 CCA) in the group 75 size, and only has side terminals, plus it can be serviced through removable fill caps. No hydrometer, though. I always try to get the electrically largest battery that will physically fit the space. You can't have too much battery.
Old Feb 16, 2002 | 11:17 PM
88WS6TA's Avatar
OPTIMA, that is all I have to say.
Old Feb 16, 2002 | 11:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got an Everstart Max from Wal-Mart, like $60. Has 1000 CCA. Works well for me.
Old Feb 17, 2002 | 12:37 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Hey thanks guys,
vader - I read another post of yours after doing the search but I dont know where you would get one of these everready batteries.
and I would love to get an optima but I dont have money falling out of my A**.
Old Feb 17, 2002 | 12:45 AM
Joshua Leslie's Avatar
justto let u know Vader....
The Eye is only checks for 1 cell, automotive baterys have 6,I have tesed many bateries where the eye showed bad but the battery checked good.
Old Feb 17, 2002 | 10:00 AM
Vader's Avatar
I understand that the built in hydrometer is only a relative indication (not the absolute, temperature compensated specific gravity), and that it is only in the second cell, but it's better than nothing. I just think it can be a convenient feature. Then again, so is the voltmeter on the dash.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
Linson
Sep 21, 2015 01:08 PM
timonator
Sep 10, 2015 07:55 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
