Crank Pullies
Old Feb 17, 2002 | 06:44 PM
StocRoc's Avatar
Crank Pullies
What is the best way to keep the crank from turning when changing the crank pulley? I have heard of sticking a screw driver in the flywheel somewhere. How would you do this exactly? Any better ways to keep the crank from moving?? Thanks
Old Feb 18, 2002 | 10:56 AM
Vader's Avatar
Stoc,
You can remove teh flywheel inspection cover or starter adn carefully place a prybar or screwdriver against the flywheel teeth or a bolt (preferred) to effectively lock the engine. You can also use a strap wrench on the harmonic damper to prevent rotation while you remove or torque the bolt.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
