Any Tricks on Installing front timing chain cover?
Old Feb 26, 2002 | 08:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i just put my new came in and put everything back together but now i have deleoped an oil leak. Its form the timing chain cover. It looks as if the rubber seal didnt seal all the way up on the pass side. anyway to fit this insead of pulling everything back apart waterpump ect.
Old Feb 26, 2002 | 08:49 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Any Tricks on Installing front timing chain cover?
lots of silicone
Old Feb 26, 2002 | 08:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The best way is to unbolt the oil pan and let the front end drop down slightly. Put the front cover on then bolt the oil pan back on.
Depending on the year of the engine, there are 2 different front pan seals for the SBC. A thick one and a thin one. They should both come in the seal kit. Did you use the correct front pan seal?
Old Feb 26, 2002 | 08:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
? Front pan seal? I used the rubber seal that was still connected to the origional rubber gasket I saw a seal come with the gasket set but i didnt know i needed to use that one. Its an 89 Block. do i have to cut the old seal off? and replace it with the other one.
Old Feb 26, 2002 | 10:21 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
No you dont have to cut it. The 1 piece oil pan gaskets are reuaseable. Yea unbolt the pan and use a light coat of "magic mechanic helper" (silicone) on both sides. Ugg pain in the but now that its all back togather.
For anyone reading this with an older style engine 2prm and considering a cam swap, leave the front pan gasket in the timing cover and just spread some silicone on the bottem. Much easyer than forcing a new gasket in there.
Old Feb 26, 2002 | 10:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
so Can i just drop the pan and try to get it back in there? if I drop the pan will the gasket still be good? It looks to me as if the whole gasket is rubber.
Old Feb 26, 2002 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I wasn't aware that it was a 1-piece pan seal. Those are usually reusable as long as it isn't damaged. Drop the pan down a bit to get the front cover in and reinstall the pan. The seal will still be ok to use.
Old Feb 27, 2002 | 12:41 AM
bubafett's Avatar
Leave the pan alone. Save time stop leaks.
Take off the timing cover. Remove the gasket.
Clean the lip on the oil pan very good. Also clean the pan with soap and water. Rince.
Pull the cover and cut a triangle off of the square lip where your gasket goes on the timing cover. Cut the angle back the front portion facing the radiator will be the orginal diminsion. The block side will have the angle cut. This allows enough play for you to slip the cover back on over the Crank snout without pulling the pan. Think about it.
Clean the cover. Clean the cover. Wash it with soap and water. Rince.
Reinstall the gasket to the cover with yellow permatex gasket glue. Put an 1/8 inch bead of black RTV on the top of the gasket where it meets the block allow it to dry.
Reinstall the cover tighten the bolts evenly but not too tight.
Clean the pan area around wher the timing cover meets it.
Now wipe a bead of black RTV into the seem where the pan meets the timing cover all the way to the block. I say wipe because it will be flush with the two parts and not visable unless underneeth the car.
Allow it to dry before starting the car. IT WILL NOT LEAK.
6 cam swaps 4 different SBC no leaks.
You must use the Black RTV and the yellow permatex all the other is junk for this fix.
Always use soap and water and rince. It leave no residue and makes for a good bond when using the black RTV.
Old Feb 27, 2002 | 12:51 PM
Vader's Avatar
Wait until you get to an LT1 oil pan...
Old Feb 27, 2002 | 08:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Try a Ford Powerstroke 7.4L (Navistar 444) engine. We ordered an oil pan gasket and they sent us a tube of silicone. There is no gasket and getting the silicone to seal takes 24 hours before you can put oil in the engine.
Old Feb 28, 2002 | 03:39 AM
Blackened's Avatar
LMAO ! That would be the "universal fit gasket kit" ! LOL
Did they really do that ? That's funny as hell. lol
Old Feb 28, 2002 | 12:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Originally posted by bubafett
Pull the cover and cut a triangle off of the square lip where your gasket goes on the timing cover. Cut the angle back the front portion facing the radiator will be the orginal diminsion. The block side will have the angle cut. permatex gasket glue. Put an 1/8 inch bead of black RTV on the top of the gasket where it meets the block allow it to dry.
LOL Thats one of the tricks my dad taught me. It works great!! Although I always forget to do it.
SSC
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
