Installing head bolts?
Old Feb 27, 2002 | 05:59 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I'm just getting ready to bolt on a set of heads and wanna know if I should use thread lock or never seize or anything like that on them. Any suggestions would help.
Tom
Old Feb 27, 2002 | 06:02 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Incase anyone was wondering, I meant on the Head bolts themselves
Old Feb 27, 2002 | 06:18 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I have never used anything on them except oil. I have read to never use anything except oil. Make sure the bolt hole threads are clean also. This is the best way to get an accurate torque reading.
Old Feb 27, 2002 | 06:55 PM
ede's Avatar
ede
john you must be reading about fords because just about everything if not everything says to use non hardening sealer on SBC head bolts, i use liquid tefelon pipe sealer
Old Feb 27, 2002 | 10:01 PM
E-Z Rollin's Avatar
I agree, teflon sealer like ARP markets [probably regular pipe sealer] with a higher price. Otherwise whats to stop water leaks?
Old Feb 27, 2002 | 10:13 PM
justinhebert's Avatar
Just a tip I learned from work. Using never-sieze can increase torque values up to 30 percent. If anything just use some light oil.
Old Feb 28, 2002 | 11:50 AM
E-Z Rollin's Avatar
Use only oil ? What is going to keep water from seeping around the bolt threads ? Just re-read your post,think I misunderstood the question.
Old Feb 28, 2002 | 01:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Like ede said, DO NOT use oil!!! The bolts go directly into the water jacket. Use non-hardening thread sealer on the threads, such as Loctite PST (pipe sealer with Teflon) or Permatex 300 (brown gooey goop). Also, DO NOT use silicone, it will leak every time.
Old Feb 28, 2002 | 05:33 PM
johnsjj2's Avatar
Car: 1991 Z-28
I was starting to get upset there for a minute. You guys are right. Oil is suppose to be used on rod, and main bolts/studs. Sealer is to be used on the head bolts/studs. It is amazing what you THINK you read in a magazine, even after your 4th time through!!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355tpipickup
Aug 25, 2015 12:54 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
