Car cruises at 70MPH by itself Help
Old Mar 1, 2002 | 12:22 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
This is on my 90 lumina 3.1 Automatic. I'll be doing 70 75 for a while and I'll let off the gas and the car will continue to stay at that speed unless i tap the breaks fast. Any Suggs? Car has 129,000 on it but runs like a top.
Old Mar 1, 2002 | 12:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check the throttle return spring, I'm guessing FI cars use a spring. Make sure it isn't kinked. This happened to me on the highway full throttle stuck going 60mph, that was some scary $hit.
Old Mar 1, 2002 | 02:03 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Just a guess...
A short in the cruise control? (If so equipped.)
Old Mar 1, 2002 | 02:20 PM
Car: 99 Formula
Axle/Gears: 342
Originally posted by Synapsis
Just a guess...
That makes sense.
Old Mar 1, 2002 | 04:16 PM
KeithO's Avatar
There is a fairly well documented (60 Minutes or Dateline) set of known failures in cruise control units in cars of that vintage. Apparently, when moisture gets in the cruise units, it begins to corrode the connectors and they have a tendency to short.
My 83 Monte Carlo SS did this only it started doing it all of the time. I really had to jump on the brakes a few times at stop lights a few times! I replaced the unit and never had the problem again.
Could be the problem...
Old Mar 2, 2002 | 01:41 PM
mechanicalmehem's Avatar
check for carbon on the throttle plate too they usually stick closed though but hey what the hell it could do it then too
Old Mar 2, 2002 | 02:09 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Carbon i nthe plates is all cleaned out before this. HMM I did use the cruise control the night before. I'll have to check that out.
Old Mar 2, 2002 | 09:00 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Check the Idle Air Control valve if it has one. My father in-laws Jeep would do this alot. When you start it up does it idle up high. The Jeep would and you could turn it off and then back on and it would be fine. Sometimes it would just start idleing up when going down the street. It makes it hard to stop.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
midias
Aug 22, 2015 01:42 AM
matthew911
Aug 12, 2015 09:38 AM
Bull86
Aug 10, 2015 05:43 PM
