Spring Pressures for ZZ4 cam ??
Old Mar 2, 2002 | 06:12 PM
89blackbird's Avatar
Does anyone no the pressures for springs when running a zz4 cam??
Old Mar 2, 2002 | 11:31 PM
5.7lformula's Avatar
same
I have the same question. For ZZ4 and for stock cam. Thanks.
Old Mar 2, 2002 | 11:43 PM
Blackened's Avatar
▀¡ê
Old Mar 3, 2002 | 11:22 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
These are the specs for the springs used on ZZ4 engines:
Force @ 1.700": 110 lbs
Force @ 1.250": 310 lbs
Coil bind: 1.160"
Max recommended lift @ valve: 0.510"
Those are the springs I used (I originally intended to use a ZZ4 cam - another story). Information from Competition Products, from whom I ordered the springs.
Old Mar 3, 2002 | 04:03 PM
Thank You .
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
