Indexing Plugs
Old Mar 8, 2002 | 01:08 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Indexing Plugs
I have put in new regular AC Delco Plugs in my 406 (that's what was in there originally) about 3 months ago. I will be installing an MSD 6A ignition today with the MSD Blaster 2 coil, so i figured this is a good time to index my plugs. I have never done this before, so if you guys could suggest to me how much i should index them and how to go about doing it. (what will i need to get from an autostore? (a plug indexer obviously but does quality matter?) here are my engine specs:
- 406 CI
- Flat-top Hyperutechtic pistons 8.5 to 1
- Head milled .020, Block .010
- 3 angle valve job
- Stainless valve
- .030 pistons
- X rods, ARP bolts
- crank turned .010 .010
- engine line bored
- R.V. cam (3 steps over stock)
- Rhode lifter
- Final Compressions 9.6 to 1
- 63cc hoods
- True Roller Timing Chain
Old Mar 8, 2002 | 01:17 PM
sleeper's Avatar
Indexing is very simple but time consuming.
You need a permenant marker and an assortment of shims that match the plugs (ie, the ones for AC Delco plugs)... I haven't looked but I assume you can buy them from Autozone?
Hold the plug horizontal and draw a line on the ceramic portion of the plug where the OPEN side of the electrode is. Then just screw them into the head adding a shim untill the line faces towards the piston. The spark will now be facing the direction of the explosion.
Old Mar 9, 2002 | 07:22 PM
Car: 88 IROC
Transmission: auto
Thanks a lot Sleeper.
So does anyone know what would be a good gap to go with for my engine combo?
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
