air cleaner fitting
Old Mar 8, 2002 | 11:14 PM
capn_crash84's Avatar
air cleaner fitting
Ok, i have an 84 T/A. I bought that cheap Edelbrock air cleaner, the 14"x3" one. It says i need to buy this spacer to put it on. I already figured that if i need this spacer, i'm going to have to go from the 3" to a 2 1/4". My question is, what and why do i need this spacer. I have the stock power bulge hood.
Old Mar 9, 2002 | 08:17 PM
jeffs82z28's Avatar
If i'm not mistaken, you need the spacer to clear the distributor
Old Mar 9, 2002 | 08:52 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
that spacer is to clear the connection for the electronic choke. i had to do the same. i use a 3/4 inch spacer. this probably will not fit under the stock hood. i had no problem because i have a cowl induction hood.
Old Mar 10, 2002 | 09:52 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The spacer is is a waste! When you space a drop base air cleaner like your edebrock you end up with the same height as a non drop base (flat lid) aircleaner setup that flows alot more air. The NON DB will clear your choke with no problems.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
