in the heat of battle
Old Mar 9, 2002 | 04:24 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
had a throw down with a bolt today........during the battle i contemplated removing the water pump pulley so i could get a better bite.........i installed the water pump myself(its an edelbrock aluminum)........how do you loosen the bolts on the face of the pulley? what do you use to keep the pulley from turning without marring the pulley all up? i was gonna use channel locks and a rag but was afraid id bend or warp it........oh and the bolt lost and no i dont remember what i did when i put the bolts on but it was a bit easier with the water pump out of the car
Old Mar 9, 2002 | 06:18 PM
ede's Avatar
ede
impact wrench
Old Mar 9, 2002 | 09:01 PM
wasp's Avatar
how do you get an impact wrench inbetween the pulley and the radiator?
Old Mar 9, 2002 | 09:13 PM
JAY87GTA's Avatar
Air ratchet then. Don't put the socket on the bolt, leave it off so it gets a running start at the bolt. Just hold the pulley with a rag in your hand and be prepared to let go in case it doesn't break loose. Usually works pretty good for me.
Old Mar 9, 2002 | 09:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i just did it the old fashoned way w/ my last car and held it still w/ my hand and loosend them that way... Its a real PITA but it worked. The other more sane option is to use a strap wrench to hold the pully still while removing the bolts. You can get a chain type from Sears. Thats what i would recommend
Old Mar 9, 2002 | 11:40 PM
Chevy83Z28's Avatar
my dad always tought me to break the bolts loose on the pulley with the belt still on, then take off the belt and the pulley comes off 1-2-3 then... no?
Old Mar 10, 2002 | 01:03 AM
LottaBallsCamaro's Avatar
Beat it with a hammer. If that doesnt work, go buy a pump action 12 gauge and a box of slugs.
You might have been able to have some one else use a pry bar between one of the belts, that is if it was slipping.
Old Mar 10, 2002 | 02:43 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
just heat it up. should make the job a lot easier.
Old Mar 10, 2002 | 10:44 AM
Vader's Avatar
A strap wrench comes in very handy for things like that.
And before you get the idea of "Vader using a strap-on" or anything like that, it's too late - don't go there...
Old Mar 10, 2002 | 11:30 AM
Drew's Avatar
Use a wrench to hold one of the bolts and use a rachet and socket ont he one you want to remove, once they're all loose wedge the wrench between or against one of the partially backed out bolts and use it as leverage.
Attached is a very basic diagram. Don't mock my mspaint skillz.
Old Mar 10, 2002 | 11:36 AM
DM91RS's Avatar
Car: 91 RS
About time for someone to say it.
Old Mar 10, 2002 | 11:38 AM
DM91RS's Avatar
Car: 91 RS
LOL
Old Mar 11, 2002 | 02:31 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
MAD skillz yo!
Old Mar 11, 2002 | 09:53 AM
wasp's Avatar
sheer unadulterated brilliance!!!!
Fanatic1074
Oct 3, 2022 05:57 AM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
