Shift kit
Old Mar 10, 2002 | 06:20 PM
zach's Avatar
Shift kit
How can i tell for certian if my T/A has a shift kit. It shifts had and fast so i think it does have a shift kit but I would like to know for shure. From 1st to 2nd it feels like your going to have wiplash. which is why i think it has a kit. Is this how hard all transmitions shift in 3rd gens?
Old Mar 10, 2002 | 09:10 PM
89Irocz23's Avatar
the only way to really tell is to pull the tranny oil cover off and check the valve body. A lot of times our transmissions will shift hard like that if the tv cable isnt adjusted right. Can you bark second or anything like that. I would make sure your tv cable is adjusted right though.
Old Mar 10, 2002 | 09:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Be sure that your TV cable is properly adjusted, if it is too far back it will cause harder shifts, but causes incorrect line pressure. Go to the tranny board and follow transfixleo's method.
Old Mar 11, 2002 | 08:48 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Honestly I don't know how hard those kits shift, but when I bought mine about a week ago, it shifted harder than I'm used to. I've only driven sedans my whole life, so I thought that's just the way it is in sports cars. But then I noticed some coverter/clutch shake and when I checked the fluid it was as black as my oil. It had never been changed, so I did that along with the filter. It shifts a lot better now, but still has some wierd characteristics like rapid rpm increases in around shift points.
Old Mar 11, 2002 | 02:06 PM
zach's Avatar
The car will get side ways if you floor it when it shifts from first to second.
Old Mar 11, 2002 | 03:22 PM
Car: 99 Formula
Axle/Gears: 342
I would definately check the TV cable, I wouldn't think a shift kit should do that, especially on a motor w/o a lot of HP.
Old Mar 11, 2002 | 03:34 PM
zach's Avatar
I can even churp the tires into third. how do i adjust the TV cable?
Old Mar 11, 2002 | 04:00 PM
Car: 99 Formula
Axle/Gears: 342
Go to the tranny board and do a search and follow transfixleo's method.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
