PLEASE READ...cam issue
Old Mar 17, 2002 | 10:44 AM
TBIWorks's Avatar
I need to know for sure what cam my 88 GTA 5.7 has. I'm considering a cam upgrade, but based on it's current performance, I need to know how much hotter to go. IS THE CAM DATA FOR 88-89 350 AT accurate on the thirdgen tech data section? Or is it possible that I have the '87 cam??? It runs outta steam at 5 grand so I was skeptical that it had the 207/213. Thanks guys!!!
Old Mar 17, 2002 | 11:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AFAIK that cam info is correct...
The cam isn't why your car runs out of steam, it's the fact that it's TPI. TPI stands for "Tuned Port Injection", remember; it uses acoustic tuning (based on the speed of sound and the length of the runners) to produce enhanced volumetric efficiency in a narrow band, roughly from 3200-3900 RPM, at the expense of reduced volumetric efficiency at higher RPMs. It responds to mods very differently from a carb or even a TBI setup, because of its tuning effect. You can easily make the car go slower by sliding in too much cam.
With a stock-runner-length TPI, 214° on the intake is about as far as you want to go; and you need to run at least 114° lobe separation if you use a cam that large. ANy larger than that and you're into custom chip land; and beyond 220° or so, you'll definitely begin to slow the car down without significant intake mods.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
