Vader... can I speak to you on the phone???Anyone???
Old Mar 17, 2002 | 03:41 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
All i did was pulled the throttle body off... polished the top, replaced the gasket. Didn't adjust anything, I sprayed any water out of the connection befor connecting again. First I threw a 33... a minute later a 36, and the only time I touched the MAF was to remove it. Exhaust smells bad. Getting a 98 v tps setting in drive, 145 IAC. MAF gr/sec around 3000. I just tried leaving the house... drove for a few minutes then it kept trying to die, everytime I gave it gas, couldn't go any faster then 10 MPH, and if I gave it more gas, i heard a pop as if it's missing . It idles at 1500!!!. Threw no codes before I pulled the throttle body. I tried adjusting the tps and it did nothing. HELP HELP HELP.
I need to get back to college tomorrow.
If anyone can help...please call 309 925 3066... ask for Ryan.
I'd really really appreciate it.
Old Mar 17, 2002 | 03:47 PM
rezinn's Avatar
Yeah that sounds bad. Did you make sure the bolts are real tight on the throttle body? All THREE air lines going to it are in tact? The bellows on the MAF are secured well?
Spray some carb cleaner around the suspect area to see if you've got a vacuum leak, then search for it if you do. That's all I can think of that would give the code 33, besides a bad MAF sensor. Try disconnecting the MAF and driving with it. The car should run with it disconnected, and much better than you described. If it does run, start off cleaning the sensor and replacing the relays. If this doesn't work it may be a dead sensor.
Old Mar 17, 2002 | 11:23 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
The car hardly runs at all without the MAF connected. Would something so simple as TPS make my car run like this. It tries to die everytime I touch the gas. I doubt I'll be able to make it to the chevy garage without towing.
Old Mar 18, 2002 | 01:02 AM
Guest
Guest
Posts: n/a
.98v TPS in drive? Thats a problem right there. Disconnect the TPS and see how it runs. If you got the TPS wet, it may have ruined it. They do not take well to water at all.
Oh, and if it is the TPS thats the problem, you can drive it for a bit with it disconnected but its gonna run a little funny until the ECM gets used to reading off the MAF only.
Old Mar 18, 2002 | 11:21 AM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
I messed with the TPS to get a .74 in drive. Still with symptoms....code 36 went away. I made it to the chevy garage 20 minutes away, but I have to keep the rpms below 2500 or else it'll start sputtering and won't drive like it was before I crossed the 2500 mark. WEIRD MAN!!! They're supposed to call back when they find out. Yea... I did get the TPS wet and probably the IAC but blew it all out with an air compressor before reinstalling. Pray for me it's not the MAF. I don't want o buy a junk one from Autozone nor do I feel like paying 250 for GMs.
Old Mar 18, 2002 | 11:23 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
If it is, look into the SU-145.
Old Mar 18, 2002 | 12:43 PM
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
They just called and said it was the TPS. I had checked it last night and when I opened up to wide open throttle, it would barely increase... sometimes decrease. They will charge 1.3 hours 62 an hour) to fix it, 20 for diagnosis and the sensor alone is 60 bucks not in stock. Should I have them do it just in case that isn't the problem. Wouldn't I have gotten a code 22?
Old Mar 18, 2002 | 01:31 PM
camaro6spd's Avatar
$60?????? for a TPS??? that sound right? 1.3 hours labor?? WTF try 15 min....
Linson
Oct 24, 2025 02:00 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
Eric-86sc
Sep 28, 2015 11:37 AM
3.8TransAM
Sep 27, 2015 08:37 PM
david068513
Sep 18, 2015 10:36 AM
