View Poll Results: How do you install an engine/tranny combination (Standard transmission)?
Bolt them together and put them in at the same time
30.00%
Put the engine in first from the top, then the tranny from underneath
70.00%
Voters: 20. You may not vote on this poll
Engine install with or without T-5?
Old Mar 18, 2002 | 02:16 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Just a quick question about your preference when installing an engine into your thirdgen.
When I pulled the engine, I yanked the gearbox first and then pulled the engine.
When I go to put it back in I'm thinking this will be the easiest way to do it (engine first from top, tranny later from underneath) rather than bolt them together and try to stab them both at once. I don't have an engine tilter/balancer thing either.
I got to thinking about it because I'm going to mate the tranny up to the bellhousing (which will be on the engine) to make sure it's gonna slide up easily once under the car (clutch alignment). So I though, "maybe I should just bolt them together..."
Anybody have better luck one way or the other?
thanks
Clem
Old Mar 18, 2002 | 02:50 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
the clutch alignment is easier when you can have someone press on the pedal.
Old Mar 18, 2002 | 03:03 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I did mine engine first, tranny in from underneath.(mine's a T5 Manual)
I put the flywheel, clutch and bellhousing on first.
Mainly, did it this way because I didn't want to take the chance of tearing anything up during install.
Hooking up the ground connections on the back of the cylinder heads, complicated things.Ended up connecting them before the motor was resting on the mounts, so they were easier to reach.
I've done other cars with the trans bolted to the motor, but there's not a bunch of spare space in thirdgen engine compartments.
I think you've got the right idea.
-Rich-
Old Mar 18, 2002 | 03:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Easiest way is to put the trans in first, with the bell housing, clutch fork, & throwout bearing installd to it; then put the engine in, with the flywheel and clutch on it.
Old Mar 18, 2002 | 03:48 PM
camaro6spd's Avatar
did trans from under.........T-5s are light.
Old Mar 19, 2002 | 09:49 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I dropped my motor in with the clutch assembly on it. I then bolted the belhousing on from underneath, and then slid the tranny in. If you hook up the hydraulics before installing the tranny, you can depress the clutch once you get the tranny most of the way in and then the alignment doesn't matter much.
Another hint is to put the tranny in gear before installing it. That way if the splines won't line up, you can turn the input shaft by turning the output shaft (usually you'll have to stick a driveshaft in the end). Use 5th for T5s and 6th for T56s, that gives you the most mechanical advantage.
Old Mar 19, 2002 | 10:16 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i didnt use an engine tilter with mine either, but i put the engine and tranny in at once, i just put the chain on an angle to tilt the motor back, you can also jack up the car a little to clear, or have someone lift up on the tranny if you hit bottom, this was easier then when i put the tranny in afterwards
Old Feb 3, 2006 | 01:06 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
exactly how i did it last night
i hope everything went in okay...gotta get my clutch pedal fixed and bleed the system
Old Feb 3, 2006 | 03:04 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
My rule of thumb is: auto trans - put them in separate, standard trans - put them in together. Piece of cake, even without an engine tilter. Everything is easier to line up outside of the car, not from underneath. I've tried both ways, and it all comes to down to a matter of personal preference. I've done it enough to be able to pull one, drop in the new in about an hour or two, depending on how "motivated" I am at the time. As a matter of fact, I will be pulling the 305 and dropping in my "back-up" 350 that way tonight/tomorrow morning. I'll take some pics if you like, but most likely will just be pulling the motor from the van tonight.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
