Question..casting numbers....
Old Mar 18, 2002 | 04:59 PM
John Rock's Avatar
My friends got a 305 block. He believes it to be a L69. The casting #'s on the block read LG5.0 SGI. Then on the other side it reads14093627. Is it possible that its an LG4?? Thanks-Rock
Old Mar 18, 2002 | 10:41 PM
John Rock's Avatar
ttt
Old Mar 18, 2002 | 11:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Casting number 14093627 = 1988-1994 305 engine.
Casting numbers don't tell you very much. The same casting can be used on many different models over a number of years. Look for a suffix code on the pad in front of the passenger side head. The suffix code will tell you a lot more about an engine. The suffix code will be stamped into the block.
Old Mar 19, 2002 | 01:29 AM
Blackened's Avatar
He's right. The casting number doesnt make an L69 and L69. It's the better cam and better exhaust manifolds... etc that do.
tyeo098
Nov 3, 2014 08:45 AM
86IROCTHD
May 22, 2005 03:51 AM
camaroz28norway
Sep 1, 2004 06:10 AM
