new motor swap dyno numbers :)
Old Apr 10, 2005 | 10:02 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
ok so i installed my motor.. and had it running on a driveability tune from john millican... i got a pretty good numbers.... 277.7@5800 rpm and 303.3 torque @ 2800..... again this is on a drive ability tune... hehe and it was running about 13 to 1 on a/f....
mods
355
trickflow 23 degree heads with 1.5 roller rockers
comp cams magnum 292 cam, .501 lift, .244 duration on a 110 lsa...
stock lt1 intake with a bbk 58mm throttle body with 24 lbs injectors...
hooker 2055's and a 4 inch mufflex cat back...
with a good tune it should be well over 300 hehe
i need to see if i cant scan the dyno sheet
Attached Thumbnails new motor swap dyno numbers :)-motorhehe.jpg
Old Apr 10, 2005 | 10:25 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That is one huge cam for a 355 cubic inch motor. 244 degrees on the intake side!!! 13:1 should be pretty close on the A/F ratio. By the way with a cam that big your peak horsepower should be well into the 6000rpm range if not higher.
I would love to see the dyno graph. I assume this is with a manual transmission. If an auto I would assume a high stall. Allen
Old Apr 10, 2005 | 10:54 PM
86IROCTHD's Avatar
Car: 88 Trans Am
yea its a stock 700r4 with stock stall for now and its not on a performance tune... its a driveability tune.... no real performance to it at all all set to stock sensor/timing spots.... only running for 3 weeks
Attached Thumbnails new motor swap dyno numbers :)-dyno1.jpg
Old Apr 11, 2005 | 08:57 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Congrats man.
Old Apr 11, 2005 | 12:25 PM
Car: 1989 GTA
Engine: 369 TPI
Above 5000rpm you are leaning out big time. More power to be had there and possible motor safety issue the way it is leaning out.
Old Apr 11, 2005 | 11:32 PM
86IROCTHD's Avatar
Car: 88 Trans Am
yea i think it might be in the chip.... will have it tuned here within a week or 2.... heck might even be the fact that i am running the stock lt1 fuel pressure regulator..... hehe and or mabye a fuel pump falling short... who knows but it sure did sound MEAN and scott settelmier-fbodyfather (SP) was impressed hehe
Old Apr 16, 2005 | 12:08 PM
86IROCTHD's Avatar
Car: 88 Trans Am
bout to get a new tune on the chip and fab up a cold air intake of sorts... so i will let yall know the new numbers
Old May 20, 2005 | 12:13 AM
86IROCTHD's Avatar
Car: 88 Trans Am
well i fixed the fuel problem.... bad pump... so now i have the pump changed and a new tune... so i am off to the dyno tomarrow to see what she will do....
Old May 20, 2005 | 03:32 AM
Spdfrk1990's Avatar
sweet
Old May 22, 2005 | 03:33 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
So how did it go?
Old May 22, 2005 | 03:36 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Oh and when are we going to run busted tranny vs busted tranny? Ive decided im converting to a auto havent decided if im going to build a 700R4, TH350, or a TH400. Im getting tired of missing gears
Old May 22, 2005 | 03:49 AM
Spdfrk1990's Avatar
Why not a t-56
Old May 22, 2005 | 03:51 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Im tired of messing with a manual.
1992 Trans Am
May 10, 2023 07:19 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
