can someone help to get my car running
Old Mar 19, 2002 | 10:07 PM
chrisandkristin's Avatar
my car has not started in 6 months , ok here it goes i bought a pair of taylor spark plug wires and put them on the was running fine but the headers burned through one of the wire so i went with moroso blue max wire and after i put them on the car would not start i have put some post up about and got some good feed back but nothing has work . so far i put a new battery and battery cables tested the starter and bought some cheap factory fit wires and still nothing . when i turn the key and try to start it all it does is start to crank the engine but it just won't turn over ,if i put the pedal to the floor some times it will start but die if u do not keep your foot on the gas i am thing the fuel pump ,then the alternator but i do not know . i have a 89 camaro with the LB9 and a 5 speed if that helps anyone ...thanks for any input on this topic
Old Mar 19, 2002 | 10:24 PM
WaynesRS's Avatar
Find out what your fuel pressure is suppose to be and test it .
Check all your vacumn hoses .
Goodluck , I feel your pain man !
Old Mar 19, 2002 | 11:16 PM
Vader's Avatar
CK,
As long as the battery is fully charged, the alternator is irrelevant. The engine should start and run for hours without an alternator on a fully charged battery.
Recheck the firing order and plug wire routings.
Check the fuel pressure and flow.
Make sure you have correct ignition timing.
Report back with results and we'll get your car running.
Old Mar 19, 2002 | 11:40 PM
GhostRider84's Avatar
Pull a plug, reattach the plugwire - lay it on some bare metal on the engine for ground. Watch it while someone cranks the motor, to see if you have any spark.
OR - - - - have your little brother hold it while he touches the motor & you crank it over - he will tell you if you have any spark!
Old Mar 20, 2002 | 02:07 AM
gonzo350's Avatar
had a very similar promlem.....was a bad fp regulator even though my fp tested fine (it had a tiny pinhole in the diaphram and was flooding the engine to death) mine too happened just out of coincidence with a tune up.....just bad timing...
Old Mar 20, 2002 | 03:46 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I second Vader..if your car ran before you changed the wires...you most likely have the wires....firing order mixed up.
Old Mar 20, 2002 | 09:14 AM
Vader's Avatar
From the River Valley Crew ( Riley and me ):
In case you were wondering...
Old Mar 20, 2002 | 01:57 PM
jfox55's Avatar
Maybe you fouled your plugs, have you checked that. Go out and buy a set of plugs and try it if not. Does your car smell like it is flooding when you crank. Are you getting fuel. And also I agree with the above have you checked your firing order.
Old Mar 20, 2002 | 06:07 PM
thanks for all your information i will get cracking on what was said in the post and keep you guys posted thanks again.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
