Can you reuse not-so-old head gaskets?
Old Mar 23, 2002 | 09:22 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I have some pricey .015 steel shim Fel Pro's I just pulled off my firebird....and I'm about to do a head swap on my buddies firebird, could I use my head gaskets on his car to make things a tad cheaper? They look good except they need to be cleaned. I was gonna apply so more head gasket sealer spray too.
Old Mar 23, 2002 | 09:35 AM
drdark's Avatar
I've had friends use their old steel shim gaskets with no problem, but for the small price, its worth the piece of mind to install new ones.
Old Mar 23, 2002 | 10:20 AM
topdown's Avatar
I wouldn't recommend it--a lot of damage can be caused by a blown head gasket--It's not worth the risk!
Old Mar 23, 2002 | 01:11 PM
Stroked-Z's Avatar
NO.
And i don't think you really feel like doing the job twice.
IMO, buy a new set & give yourself peace of mind.
Old Mar 23, 2002 | 04:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Absolutely not, if they're steel-shim ones. All the stamped patterns in them are now flattened, so they have no chance whatsoever of sealing again. When you pull them out you'll probably also find that they're leaking like they always do. Frankly I don't know why anyone would ever use them, the "theoretical" compression isn't worth their "real world" dysfunction.
Decent gaskets like Fel-Pro blue ones sometimes can be re-used in a pinch. It's not something you should ever do unless you are really desparate, or you just enjoy pulling heads off.
Old Mar 23, 2002 | 06:34 PM
ede's Avatar
ede
why would you want to risk it. if the cost 500 dollars i'd still trash them to keep from going through the hassel of fixing a leak
Old Mar 23, 2002 | 07:59 PM
GreenProStreet's Avatar
The compressed thickness of the material will decrease, thus increasing the compression. The risk of detonation and blowing it, is not worth the risk, or $30 in gaskets.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
