code 13 after header installation
Old Mar 24, 2002 | 02:16 PM
breathment's Avatar
Im getting a code 13, Oxygen sensor signal stays lean during warm engine cruise, after about 10 min of driving on the highway. I didn't replace the O2 sensor, since I replaced it a couple months ago. i do have a SLIGHT leak which i think is near the collectors. BUT i do not have the AIR system working right now. The box and hoses going to the headers aren't hooked up. is there any chance that is the cause of my code 13?
Old Mar 24, 2002 | 05:41 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
code 13 is not the lean signal
code 14 is the lean signal
code 13 is not signal coming from the o2 sensor at all i would check the wiring
if thats not bad you need a new o2 sensor
when i did not have it hooked up in my car i got a code 13
check wiring or replace it
Old Mar 24, 2002 | 05:48 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Most people I have heard from recomend a heated 3 wire O2 sensor when running headers. I guess sometimes a stocker can't reach operating temp with the difference in heat retention of headers. This might or might not be relavent, but you should consider one if it isn't already set up as such.
Old Mar 24, 2002 | 06:58 PM
breathment's Avatar
14 is definatley High temperature indicated at engine coolant temp. sensor ...
but iv seen a few diff. things for 13.. TGO says 13. Oxygen sensor signal stays lean during warm engine cruise
while my TPI books justs says O2 sensor circuit (open)
oh well ill do the obvious and check the wiring later
Old Mar 24, 2002 | 08:12 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
yep i had to install a heated sensor when i put in headers.....i have an accell no problems but the car ran like s*** b4 i swapped the stock one out
Old Mar 25, 2002 | 10:28 AM
Vader's Avatar
Breathe,
You are correct - TGO is wrong. The '14' is for a CTS circuit short (high temp fault) on your engine. A '13' is for O² signal loss or out of range - not a "constant lean in cruise" - that would be a '44'.
Check your wiring and grounding on the headers, and make sure the exhaust gets nice and hot.
Not having the A.I.R. connected won't matter once the ECM is in closed loop, at least as far as the O² sensor is concerned, unless of course you have air leaks at the A.I.R. fittings on the headers.
Old Mar 25, 2002 | 10:40 AM
TBI305Camaro's Avatar
i havent had any problems with the o2 sensor giving me codes and i tore all the smog crap off luckily our carsonly have 1 o2 sensor unlike my dads mustang or the newer style camaros...cant even run a off-road h pipe on my dads because it takes o2 reading after a set of cats...then it goes into another set of cats....hear the new mustang GTs have 6 cats...why??
Old Mar 25, 2002 | 09:39 PM
breathment's Avatar
whoops.... was tightening the collector bolts on the exhaust and saw the O2 sensor harness just dangling. hooked it up and it runs great now.. thanks
Old May 17, 2008 | 09:53 AM
gotay5's Avatar
Re: code 13 after header installation
same problem on my 1991 z28 camaro tpi 305 runs great but code 13 after header installation
hectre13
Dec 11, 2023 08:14 AM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
