how much power will I gain with this cam?
Old Mar 29, 2002 | 07:53 PM
Joshua Leslie's Avatar
hey
engine is a 350, stock 75cc mexico smoggers, shorty headers, performer intake, Edelbrock 600carb.
The cam in there now is 204&214@.050,with .422&.444 lift, total duration is 262. I dont know who makes the cam,I think it may be Crane under another name. I got it from a local engine shop.
I was thinking of swapping in a comp cams x/e 262 or 268.
Old Mar 31, 2002 | 10:10 AM
84zeddd's Avatar
Ran your set-up on the desk-top dyno.
Present cam=270hp.@4500 and 358lbs/ft@3500
xe-262=294hp.@5000 and 356lbs/ft@3500
xe-268=300hp.@5000 and 340lbs/ft@4000
You should see a .15-.3 improvement in e.t.
If it was my car I would probably save for a set of heads and do
both at the same time but thats your call,hope this helps
Old Mar 31, 2002 | 01:32 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
20hp easy with the mildest one
gta90
Sep 15, 2015 04:00 PM
neekolzun
Aug 24, 2015 04:59 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
