Hard Starting
Old Mar 31, 2002 | 08:29 AM
fahq's Avatar
Hard Starting
I just bought an 88 formula and it starts hard when it is cold or if I let it sit for a little bit. I am not sure what the problem is.
Old Mar 31, 2002 | 09:52 AM
Tonyrodz's Avatar
Transmission: auto
Might be the fuel pump going out--very common problem!
Old Mar 31, 2002 | 10:32 AM
fahq's Avatar
How can I check if it is the fuel pump?
Old Mar 31, 2002 | 02:53 PM
Tonyrodz's Avatar
Transmission: auto
Is it a tpi or tbi car?
you could check for fuel pressure too.
Old Mar 31, 2002 | 06:23 PM
fahq's Avatar
It is a 350tpi. Someone told me it could also be something called the cold start injector?
Old Mar 31, 2002 | 11:44 PM
Tonyrodz's Avatar
Transmission: auto
Does it throw a code? It's possible on the 9th injector tho.
Old Apr 1, 2002 | 02:16 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Could be injector leak down, bad chip, or dying fuel pump.
Old Apr 1, 2002 | 08:41 PM
fahq's Avatar
How can I tell if the fuel pump is going? Could I check the leak down of the injectors with a fuel pressure guage? I have a Haynes manual and it is worthless. It does not show you how to trouble shoot anything.
Old Apr 1, 2002 | 09:06 PM
Tonyrodz's Avatar
Transmission: auto
A fuel pressure gauge would help ALOT!! That would be the best place to start. Just put the ign in the run position to prime the pump and see what the pressure is--don't start it--and see if the pressure drops--then go from there.
Old Apr 2, 2002 | 07:44 PM
fahq's Avatar
I put a fuel pressure guage on it and it read about 48 psi I fired it up and the pressure did not drop. I shut the engine off and the pressure did not drop. How do I test the ninth injector?
Old Apr 3, 2002 | 08:00 PM
fahq's Avatar
It gives a little puff of smoke out the exhaust when it starts and it smells like gas. Almost like it floods or something.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
