a follow up post to "ported or polished"
Old Mar 31, 2002 | 04:28 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
has anyone actually bolted on l98 aluminum heads to a 305? if so how does it run and did you have any valve shrouding issues? also how can you tell if valve shrouding is or will occur? see "ported or polished " for the full scoop and thnx in advance
Old Mar 31, 2002 | 09:59 PM
DABE's Avatar
I would like to know about the installation of the L98s on a 305...i have a mild/wild setup on a 305...and the stock heads need to go.....how much should these heads cost??...about how much HP gain??...are they a "direct bolt-on"?
Im really interested in this topic
DABE
Attached Thumbnails a follow up post to "ported or polished"-small_6318477_7857740.jpg
Old Apr 1, 2002 | 04:02 PM
wasp's Avatar
zzzzzzzz
Old Apr 1, 2002 | 04:08 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
They are sortof a direct bolt on. They have the pre-87 style intake bolt angles so you'll have to get a pre-87 intake. Don't know about the shrouding...sorry .
Old Apr 1, 2002 | 04:09 PM
Mark305TBI's Avatar
Oh yeah...I've got pictures and flow numbers up on my website if you guys are interested.
Old Apr 1, 2002 | 04:44 PM
rezinn's Avatar
I've got them on my 305 and they work fine. I have an edelbrock tpi intake so I didn't need to do anything, although elongating the bolt holes on a post-86 manifold will work fine. They have D shaped exhaust ports so some headers don't work great with them, such as edelbrock(which I'm using, unfortunately). They can be directly bolted on with decent improvements IF you have aftermarket parts. On an otherwise stock engine it is a waste.
Regular L98 heads are a bit big and will kill compression with stock pistons, just so you know DABE. These aluminum L98s from vettes have 58cc combustion chambers, same as stock 305s. They have larger valves, which some people think will cause shrouding on such a small bore. While this may be true, I've had no such issues on my engine. My heads were professionally ported before I put them on nine months ago. I ran mid 14s at 96mph last year, but I had very bad traction and horrendous 60 foot times. FYI Kevin91Z is running 12s with these heads on his 350.
Old Apr 1, 2002 | 06:16 PM
wasp's Avatar
i have an edelbrock tbi intake, should i call them and ask if the bolt pattern will match ? or do you guys know? as for the headers i have hookers on the stock heads now.....i assume they will match up, is plug angle the same on the l98 alum heads? i have no header to wire conflicts now im hoping it stays that way..............alot of things to look into when buying heads ,sorry for all the questions
Old Apr 1, 2002 | 06:43 PM
DABE's Avatar
watch out...compression is gonna drop......shave them....im going with different heads...maybe the bowties....my 2 cents.... DABE
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Chuck84TA
Jul 15, 2016 09:05 PM
mx127
Aug 10, 2015 08:13 AM
