Help with LT1 intake conversion!!!AHHHH!!!!
Old Apr 2, 2002 | 07:07 PM
JucinGTA's Avatar
I am about 2 run the LT1 intake conversion from LT1intake.com and I just found out from my buddy that I might be lean on 2 of my clynders because of the differnce in firing order between the LT1 and the TPI. Anyone know anything about this?
Old Apr 2, 2002 | 07:47 PM
rezinn's Avatar
I think your buddy has no idea what he's talking about.
Old Apr 2, 2002 | 07:48 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
The firing order is the same as it always was...Lt1's are no different. The only thing I do recommend is a PROM burn to not be running lean or rich. Your ECM now will see a lot more air then it's used to, so you need to recalibrate the PROM.
Old Apr 2, 2002 | 08:53 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Firing order? What is he smoking? All you are changing is the intake............
Old Apr 3, 2002 | 02:43 AM
Jza's Avatar
Jza
He's been reading too many magazines and not doing enough wrenching. Only the LS1s have a different firing order. Kinda hard to screw it up, though since there's a seperate coil for each cylinder right above it.
Old Apr 3, 2002 | 09:02 AM
JucinGTA's Avatar
Hey the guy is not stupid but maybe I phrased him wrong I will have him type what he told me.
I have DFI, so I wont have to worry about the Prom.
Thanks for the quick response!!:hail:
Old Apr 3, 2002 | 09:06 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I've heard of air distribution problems to the #7 and #8 cylinders with the LT1 intake on forced induction setups ....but it's definitely NOT because of the timing. Maybe that's what he means???
Old Apr 3, 2002 | 02:25 PM
rezinn's Avatar
n
Old Apr 3, 2002 | 08:33 PM
JucinGTA's Avatar
Ok heres what he had so say:
actually as soon as you left I remembered why it runs lean. The fuel lines run differently for the LT1 intake over the L98 style. This causes the lean condition
Anyway that is the reason it had 2 lean cylinders. After alot of research into why it ran like **** it was determined that due to the way the fuel lines run for the LT1 and the injector pulse it caused a lean condition. After changing to the L98 intake no more lean cylinders
Old Apr 3, 2002 | 10:20 PM
Engine: 4.0L
No, it runs lean with the LT1 intake because prom burning IS REQUIRED. You are getting a whole lot more air in there compared to the TPI intake. It has nothing to do with the fuel routing. If that were the case we would re-route our fuel lines instead of burning proms.
Old Apr 4, 2002 | 08:52 AM
JucinGTA's Avatar
Sweet!!!!:hail:
Old Apr 4, 2002 | 08:55 AM
JucinGTA's Avatar
Hey I have the intake, how long we looking at this taking?
Old Apr 4, 2002 | 11:03 AM
Engine: 4.0L
You need to e-mail me directly.
john@lt1intake.com
Old Apr 9, 2002 | 07:27 PM
JucinGTA's Avatar
Well I did so and I havent gotten a response!!
Old Apr 9, 2002 | 09:00 PM
Engine: 4.0L
Yes you did.
Old Apr 10, 2002 | 06:03 PM
JucinGTA's Avatar
Did I?
Can you resend it
92projectcamaro
Jan 18, 2016 08:00 AM
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
