Help my Heads Have No Holes
Old Apr 3, 2002 | 03:32 PM
Z28SpeedKing's Avatar
i bought a set of camal hump vette heads and they have no ACC holes, has anyone ever made thier own custom brackets for the alt/power steering. I know that i can buy them but they are like a total of 200bux that i dont have. If anyone could help me it would be great
Old Apr 3, 2002 | 05:48 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
go to a boneyard and strip all the brackets off of a junker sbc and make some templates out of cardboard so you know where you have to drill and tap your heads. just dont hit any water jackets.
Old Apr 4, 2002 | 07:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You can't drill & tap them, there's nothing there to drill, only the thin casting wall (about 3/16" thick). There's no bolt boss like the right heads would have, and the surface of the head is about ¼" too far rearward anyway. And since there's only ¼" of room, there's no way to make brackets to fake it either.
This is why we all told you not to buy those heads when you first asked: we've all been fighting this same issue for the last 30 years now, and if there was a reliable way to make it work, you wouldn't be seeing the no-bolt-hole heads for so cheap.
Old Apr 4, 2002 | 10:48 AM
bradkeith's Avatar
there is a set of brackets on e-bay for cheap right now. 39.99? They let you mouny your accesorries to your motor if you don't have bolt holes in your heads.
Old Apr 4, 2002 | 01:25 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I never figured out how to mount my a/c compressor, so as it sits I don't have AC until I dump my junk 461 heads.
For the alternator, I ran it without the head bracket for a while with no problems, but a couple years ago I went junk-yard shopping and took all the tubular brackets and braces I could find. I got one that was around the right size, and I bent it to go from the back of the alternator pivot bolt to the header bolt. I've put well over 10k miles on it and I haven't thrown a single belt yet.
Old Apr 4, 2002 | 01:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd be interested in seeing that link... I couldn't find it by searching... I'd like to see how that's going to work, considering the realities of the situation
Old Apr 5, 2002 | 05:26 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I had the same problem...I got the brackets for the power steering....at the jy....I deleted the ac....with a little luck and a shim here and a shim there..and a real tight bolt...you can make it work....I used the stock ac bracket, only part of it, attached it to the first header bolt hole, using a stud instead of a bolt, I held the bracket on with a nut..then shimmed it out to align the belt...tightened it up real tight......no problem since......You can do it.
PS
Im using the" long" waterpump
Old Apr 8, 2002 | 06:17 PM
Jim you got any pics of the brakets that you made
Old Apr 8, 2002 | 06:20 PM
Jim85IROC's Avatar
No. It's just 1 rod that goes from a header bolt to the back of the alternator. Nothing too special.
Old Apr 8, 2002 | 06:25 PM
what about the power steering
Old Apr 8, 2002 | 10:58 PM
firepheasent's Avatar
Their is a company that makes a one peice bracket for a sbc (tpi serpintine set up) its made up of alluminum casting and uses only the bolts on the block . but the cool thing about it is that it made to bring all of the accessorys closer together top to bottem right to left and its very clean looking peice. It was made for street rods using tpi set ups. It was in last months chevy high performance aprils issue. Its made by vintage air, 1-512-654-7171 or 1-800-to-cool-u. I believe its takes a special alternator for becouse of the way it attaches but the sell it too.
Old Apr 9, 2002 | 12:03 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Did you buy those camel hump heads off ebay? I saw 'em and almost bid on some. What'd you pay?
Excuse me for prying.
Old Apr 9, 2002 | 12:28 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i have a set of 461 double hump heads, i have heard over and over about how these heads wont accept late style alternators. the heads i have has the bolt hole brazed in it. this accepts the alternator, but there are no other holes for A/C. i dont know if thats possible or not. if worse comes to worse, you can always weld the bracket to the head. lol.
Old Apr 9, 2002 | 05:44 AM
Nope not the ones off ebay,i bought mine off a good friend, they are all rebiult, they have screw in studs, valve guides, they have never been started. I got them for 400.
Jeremys87
Jul 14, 2022 09:08 PM
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
355tpipickup
Aug 27, 2015 08:13 AM
89mulletbird
Aug 12, 2015 07:08 PM
