Knock Sensor not working!!!
Old Apr 8, 2002 | 04:35 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
alright I just replaced the connector cause it was broke and I replaced knock sensor and it doesn't work, I have a new one and hooked it up and still does not retard time, I check the wires and didn't see that its grounding out, also tapping on the block and not getting any reading from the sensor, whats going on with this thing? I m not getting any codes either
Old Apr 8, 2002 | 05:45 PM
ede's Avatar
ede
you getting knock counts? check the EST
Old Apr 8, 2002 | 06:00 PM
v8powr's Avatar
howdo you check knock counts?? And what is EST?? No...im not a rookie
Old Apr 8, 2002 | 06:14 PM
ede's Avatar
ede
check knock counts with a scanner and i should of said ESC, eletronic spark control, or EST eletronic spark timing. either way check the "thing" that changes the timing to see if it works
Old Apr 8, 2002 | 07:35 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well i m not getting any knock counts at all, and my timing isn't retrading either. So I changed the module out not to long ago, and I checked all of the connections and everything is plugged in. So I m kinda at a loss, I did get a EST code awhile back but it went away. So does this help?
Old Apr 8, 2002 | 07:46 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If the ESC module works and the spark knock sensor is new, then I'd say your not getting knock.
Old Apr 8, 2002 | 07:56 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
no I'm getting knock, trust me and my timing won't retard at all, even when I m getting preignition.
Old Apr 8, 2002 | 10:02 PM
RICHRAD's Avatar
Is that the sensor on the engine block in front of the starter? Should it be replaced if one doesn't know its history? How/ can we tell if it's even working properly?
Old Apr 8, 2002 | 10:31 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
yeah thats the sensor, well one way to tell if its working, you need a scanner and you can moitor the knock sensor, and you bang on the block and if its working it should retard your timing back. as if your getting preignition cause its bascailly like a microphone for your ignition system, well usually they don't go bad this is what I m told, by my buddy whos a mech, unless your car is laughing at you like mine. but anyway the most common reason is cause crud from your coolet builds up behind sensor and keeps it from listening/ working. Like I said thats what I ve been told, Well my prob is that mine won't respone. And I get knocking underload. I m going to try a new module, maybe that will help I hope.
9192camaro
16
Feb 3, 2019 12:21 AM
db057
Aug 22, 2015 08:17 PM
squiggy2
Aug 9, 2015 09:30 PM
gwade12
Aug 8, 2015 08:17 AM
