Help! 91 RS 3.1 V6 Camaro
Old Apr 13, 2002 | 01:31 PM
Jannsjunction's Avatar
Do you know of any computer related problems where the car will flood over for no appartent reason? I have replaced the coolant sensor on the intake and the idle air charge and the Map.
P.S. I get a over charging code forgot to mention I also bought a new alternator and i get a rich exhaust code forgot to mention I bought a new oxygen sensor,I also get a mixture control code and yes I have ran a check on the fuel pressure regulator and fuel injectors all I know what is left is the ECM. Can any one HELP!??
Update:
Had a blowed intake gasket,but not blowed all the time sometimes it leaked somtimes it didn't. Put a new coolant sensor in it again ,found out the old new one was faulty. So far have removed the top intake plentum, fuel injection rail, I have figured out that i either have to loosen the distibutor and turn it or remove it to remove the bottom intake plentum, because of one bolt that sits right below the distibutor.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
vortech305
Jun 3, 2001 11:24 AM
elevario
May 14, 2001 04:41 PM
