Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
View Poll Results: Who would win ,if they lined up?
'73 455 SD
30.56%
'89 TT/A
22
61.11%
It's to close to call.
2.78%
It would never happen ,they would never meet.
5.56%
Voters: 36. You may not vote on this poll
Who would win?
Old Jun 8, 2002 | 07:32 PM
SOLID LIFTER's Avatar
Car: '87 Mustang LX
Engine: 5.0
Who would win?
If by some act of *** a '73 455 SD T/a and an '89 TT/A lined up on the main drag ,who would win? They both ran low 13's without a problem.
Old Jun 8, 2002 | 07:53 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
TTA without a doubt
Old Jun 8, 2002 | 09:43 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Originally posted by 1991tealRSt-topGuy
TTA without a doubt
Agreed.
Old Jun 8, 2002 | 10:10 PM
IMHO, second gens were beautiful, but were POS's in many respects
just as most cars from that era
Old Jun 8, 2002 | 10:58 PM
Car: 99 Formula
Axle/Gears: 342
I sort of agree. I had a '76 TA, most reliable car I've owned. Only got 12mpg and was slow, but nothing could hurt it.
Old Jun 8, 2002 | 11:26 PM
SoCo80p's Avatar
the SD-455 would whoop the living **** out of a TTA it ran low 13's stock and thats back in 73' when they still had the rock hard bias ply tires, on a radial it would be a high 12 second car
Old Jun 8, 2002 | 11:38 PM
Car: 99 Formula
Axle/Gears: 342
Then how come for years, not sure with new Ram Air TAs, but the TTA was the fastest production TA ever.
Old Jun 9, 2002 | 01:03 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
TTA's run low-mid 13's. The other car is fast, but I think they run 13.90's. Considering both are stock of course. I say TTA here.
Old Jun 9, 2002 | 01:06 AM
SoCo80p's Avatar
point i was making is dont forget when they tested those engines back in 73' that torque monster 455 with with 225/70/15 bias ply tires would just melt the entire 1/4 mile, the TTA will pretty much hook and go givin the better tires. also the TTA was nearly 1,000 lbs lighter and the SD-455 had 8:1 threw horrible exhaust and a weeny cam. check out the pure stock drags, SD-455's are all low 13's high 12's with fatter radial tires. the SD-455 was the mother of all pontiac engines thats forsure
Old Jun 9, 2002 | 01:14 AM
Administrator
Everything I have seen for them is high 13's-low 14's. But thats all I have seen.
Old Jun 9, 2002 | 01:17 AM
SoCo80p's Avatar
it really depends on the setup, the cars in those days varied setup as much as diffrent chicks ******* sizes the TTA was basically just one setup, the SD-455 could have the auto or 4-speed, 2.73-4.30 gears and other option, the most common test is a 74' with a auto and 3.08 gears, the test says it was done on a 40 degree day and the car spun the tires 60' and ran a 14.1 but with better gears, traction and a 4-speed the times were much better
Old Jun 9, 2002 | 05:17 AM
Car: '87 Mustang LX
Engine: 5.0
I think you've got the RA TA's and SD's mixed up, the SD ran 13.54 in 73 with a serious traction problem( They run much quicker than this ,even),and the 70 RA IV ran 13.90 in 70.
Old Jun 9, 2002 | 10:22 AM
Car: 99 Formula
Axle/Gears: 342
Either way, I guess it would be close, but I would have no doubt as to which I would rather own. Just look at shrp1's car, not much modding and he's hoping for 10s..Wow.
Old Jun 9, 2002 | 11:26 AM
Car: '87 Mustang LX
Engine: 5.0
They're both great cars, the SD is also easily modified ,a set of slicks, frame connectors,traction bars ,headers ,and tuning and it would pull low 12's high 11's without even thinking about it.:rockon:
And I know what the :hail: TTA can do thats why Im asking ,to see what everybody else thinks,cause Im not sure who would win.
Old Jun 9, 2002 | 03:20 PM
SoCo80p's Avatar
you've got it right soild, the SD with a hotter cam, headers, put dual exhast on it and slicks and they will run high 11's all day, on a tta with some bolt ons would be 12's no problem, it would be a showdown but i'd have to give it to the SD-455
Old Jun 9, 2002 | 04:36 PM
Car: '87 Mustang LX
Engine: 5.0
SD's had duals from the factory ,my '73 400 formula came with duals even ,dual exhaust was avalible thru the end of '74.But you could deffinatly benifit from aset of 2.5" duals. as for the cam that was a nice ra iv spec peace with .470" lift and 320* duration ,a solid cam would really wake up an SD like you said high 11's would be no prob.Shaving the heads down a little too would be cool too.SD'S RULE.
p.s. how do I join LALA racing?:lala:
Old Jun 9, 2002 | 04:51 PM
Administrator
OK I found an official time for that car and it is 13.54@104.29MPH. I still say TTA. Keep in mind we are talking both cars all stock here or close to it. 1 things for sure though, it would be a good race.
Old Jun 9, 2002 | 05:06 PM
Car: '87 Mustang LX
Engine: 5.0
Thats the same time (minus the mph) I posted about 5 posts back keep in mind thats on stock $#!+ tires, and magazine times are always a little slow ,I mean look at the test hotrod did on the TTA when it was new 14.21 @ 97.8 mph WTF they must of had an 89 year old women driving that thing, you can't beleive those mag tests ,cause both the SD and TTA where alot quicker than what hotrod and motor trend would have had you beleive.
Old Jun 9, 2002 | 05:12 PM
SoCo80p's Avatar
Chaos rampant,
An age of distrust.
Confrontations.
Impulsive sabbath
Old Jun 9, 2002 | 05:17 PM
Car: '87 Mustang LX
Engine: 5.0
On and on, South of heaven.:hail:
On and on, south of heaven :rockon:
Old Jun 9, 2002 | 05:18 PM
SoCo80p's Avatar
now you can offically join bow to la la racing
Old Jun 9, 2002 | 05:25 PM
Car: '87 Mustang LX
Engine: 5.0
:hail: :lala:
Old Jun 9, 2002 | 10:23 PM
Administrator
Only way to know is to race.
Old Jun 9, 2002 | 10:56 PM
iroc22's Avatar
That's a really good point. All the times from the 60s can basically just be forgotten about because of the pencil-width, hard as a rock, bias-ply tires. I have a test in front of me for a 67 L71 Vette that ran 13.8@111mph
Old Jun 10, 2002 | 08:46 PM
Car: '87 Mustang LX
Engine: 5.0
They ran the '62 421 SD to a 13.9 on frickin 6" wide bias plys to!
Old Jun 13, 2002 | 03:39 AM
SoCo80p's Avatar
finally someone with a brain! yes i really get annoyed with people saying "this and that new car ran just as fast or faster then the old cars" but what people just dont factor is way back in the 60's and 70's cars has at the fattest a 225/70/15 rock hard bias ply tires behind torque monster engines that 60' would only be tire smoke, one test i saw that was great was in 68' the GTO ran a 13.7 factory stock but on slicks ran a 12.9
Old Jun 13, 2002 | 03:46 AM
SoCo80p's Avatar
Early 60's SD-421, now thats what im talking about heres one for you,............waiting for the hour of reprisal, you time slips away,.......(guitar),......
Old Jun 13, 2002 | 06:29 AM
Car: '87 Mustang LX
Engine: 5.0
:hail: :hail: :hail: :hail: :hail: :hail: 410 HP 13:1 421 SD !
Old Jun 13, 2002 | 06:35 AM
Car: '87 Mustang LX
Engine: 5.0
Its raining blood, from a lacerated sky,bleeding its horror, creating my structure,now I shall reign in blood.
Old Jun 13, 2002 | 06:54 AM
Car: '87 Mustang LX
Engine: 5.0
We all talk about not getting traction if we stab it off line,I dont get any with my buick with modern day 9" wide radials, but you DONT want to know the traction problems the pontiac 400's 428's and 455's had when they were running on stock tires, trust me it sucks,its WAAAAAAAAAAYYY to easy easy to do a burn out at 1/2 throttle and without even trying.
Old Jun 13, 2002 | 09:58 AM
SoCo80p's Avatar
:rockon: :rockon: :rockon: :rockon: :rockon:
Old Jun 13, 2002 | 10:03 AM
SoCo80p's Avatar
absolutly, i had a stock 70' buick lesabre 455 with only duel exhaust and the torque in that thing was unreal, at 1/4 throttle it would melt the tires 1/2 a block and that was on a 235/60/15 radial tire! the torque of the the old BOP engines is unmatched by anything out there today, amazing they got 13's out of the cars on those crappy tires back in the day, imagine if they tested them all on good tires 11 second 1/4 mile from the show room floor
Old Jun 13, 2002 | 10:18 AM
Car: '87 Mustang LX
Engine: 5.0
Tell me about it! BOP motors w/ 510 ftlbs. of torque are nothing to laugh at. My dad talks about the Grand-Am that he put a 455 w/428 HO heads in, It was a one wheel peelier ,and he constantly had to get a new tire for the rear Beacause he couldn't Contain himself.
Old Jun 13, 2002 | 03:51 PM
Administrator
I'd like to run a 302 Z28 and COPO 427 on good tires these days.
Imagine that.
Old Jun 13, 2002 | 11:56 PM
iroc22's Avatar
Imagine that.
I have a CHP from 1993 when they ran some Chevy legends. Man what a good magazine that one is. They ran the cross-ram 69 302.......
Old Jun 14, 2002 | 10:41 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i still say the TTA, and mod for mod i still say the TTA, be one hell of a race though
Old Jun 14, 2002 | 11:56 PM
Camar_Hunter_c's Avatar
For looks and glory the TTA.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
Angie Coots
Sep 23, 2015 07:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
