Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Me vs. a supercharged mustang :)
Old Sep 21, 2002 | 09:34 AM
  #51
Monkie's Avatar
Why not? Personally I was running a 125 shot, never had a problem. My block and crank can stand up to a 160 shot. My ATI Procharger arrived thursday and its going on sometime soon with 10 psi on stock everything. After I go forged its going to be 15psi with a 50 shot. Only on forged rods and pistons. You're telling me Ford's engines aren't made well? Or are you saying they cant make hp? LOL 8psi on a DOHC 4.6L will make you 500rwhp on a dyno tune. Do alittle research before you go off mouthing to people. Not starting anything just saying...
Old Sep 21, 2002 | 09:35 AM
  #52
Monkie's Avatar
Originally posted by 12sMustang
That's fair.
How much power are you talking about? Low 12s isn't a thing for the stock rotating assembly. There are plenty of people who go 10s on a 5.0 with ported TFS heads, and are still very streetable. This can still be done on stock pistons
Chris
Alot of stock 5.0s came with forged internals I've been told.
Old Sep 21, 2002 | 09:55 AM
  #53
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Brand new the A4 block will run you ~ $3000 full machined and ready to go from Bennett Racing. I'm sure you could find a better price somewhere else.
I've got several friends pushing 450+ rwhp on the stock block. One of whom is making 596 ft. lbs. of torque. He knows he's on borrowed time, but he only shifts at 5200, which should help it last a little longer than a 6000+ rpm combo.
You can spin the stock bottom end a lot higher than people think as well. I recently talked to Larry Felts (2-time FFW S/W champion) about it and he told me he's turning the stock bottom end to 7000 rpm and said I should have no problems turning 6500 rpm on a regular basis. He did recommend having the bottom end balanced and blue printed if I planned on turning it any higher though.
Old Sep 21, 2002 | 10:00 AM
  #54
Monkie's Avatar
BAH! My bottom end is built like a moose. I've taken nitrous into the 7,000rpms many time without a miss. (knocking on wood)
Old Sep 21, 2002 | 10:09 AM
  #55
TBI305Camaro's Avatar
Actually I raced my buddy in his supercharged mustang once and beat him in about like the 1/8th mile. Unless he has some suspension mods he will light them up and sit back going sideways. then he finally started moving and about lost it again when he hit 2nd. It was the craziest car ive ever seen. Probably would have ran 12s with traction
Old Sep 21, 2002 | 10:18 AM
  #56
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I think all were around 400hp at the wheels, one was 450 and the guy in the 12's said he should be running faster but can't figure it out. My nieghbor was pushing over 400rwhp with stock short blocks, victor jr. heads unknown F.I. intake and unknown cam. He has trashed many lower ends. Some of you guys may be interested in some parts I know of, in particular a rare set of heads that were designed for nascar racing and only a few were produced-I think in the late 80's or early 90's.Also lots of good aftermarket lower end peices. I'll post back later today with what everything is and how to contact if anyone is interested. Monkie you will spin a rod bearing, it's only a matter of time with the 4.6
Old Sep 21, 2002 | 10:45 AM
  #57
Nic's Avatar
Nic
Engine: 5.0L
Anyone who pushes anything hard enough long enough will break something eventually. Hell, I've been through 5 transmissions in 2 years
Old Sep 21, 2002 | 04:52 PM
  #58
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Do Yates heads ring a bell to any of you Ford 5.0 guys?
Old Sep 21, 2002 | 07:31 PM
  #59
12sMustang's Avatar
Nope, never even heard of them.
Chris
Old Sep 21, 2002 | 10:09 PM
  #60
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Well I don't think there the kind of thing your gonna see in summit or jegs.
Old Sep 21, 2002 | 10:25 PM
  #61
Nic's Avatar
Nic
Engine: 5.0L
Yates heads...WAY too big for anything driven on the street and outlawed in all of the classes except for Pro and SSO. Canted valve heads with a 2.08 intake valve I believe.
Old Sep 22, 2002 | 06:29 AM
  #62
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Is it true that saleen s281 supercharged -99 and up run 1/4 in mid to high 12s??????
Old Sep 22, 2002 | 09:58 AM
  #63
Monkie's Avatar
Try mid to low 13's. They are SCed, but its a mild tune and they are still a 2v.
Old Sep 22, 2002 | 11:07 AM
  #64
I saw an article about the s281 saleen in one of my dads mustang magazines. Ran high 11's on slicks i do believe. And mid 12s on street tires. I wouldnt classify that as a "stock" car tho.
Old Sep 22, 2002 | 04:09 PM
  #65
5.0mustang's Avatar
No that one wa the S281 Extreme. It did run a high 11 with tires, and the only other car that has done that was the Viper (or so the mag says!). The regular SC'd ones run low to mid 13s!
Old Sep 22, 2002 | 09:46 PM
  #66
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by unknown_host
not trying to start **** here but the fox body 5.0 mustangs at my track are all high 14 low 15 cars too, big deal people dont know how to drive. well kept thirdgens are rare, but i have yet to see a fast 5.0 at my track. there is a high 15 second 95 at my track with "dubs", a GT 5.0 running 14.9's and some other fox bodies even slower. dont tell me your cars are godly, everyone knows 5.0's and L98's run neck and neck.
just giving some info. besides big block powered cars, fox bodys are by far the fastest car in my area, both at the track and the streets. i may not love that fact, but here thats the way it is. oh well they all sound the same(bad *** IMO) and they all look basically the same
Old Sep 22, 2002 | 10:13 PM
  #67
unknown_host's Avatar
Car: 1989 Iroc Z L98
around here there is only 1 really fast looking 5.0. i sure wish thirdgens were as light as foxbodies. we have such a majority of newer 5.0 mustangs around here but they seem to be pretty damn slow. around here all the fast cars (all my friends' cars) are 60's and 70's chevy muscle cars, there isnt even really a ford scene, just a few fords here and there. oh well.
Old Sep 23, 2002 | 04:33 AM
  #68
DOOSKI's Avatar
Transmission: A4
So this means that LS1 and cobras are just as fast and even faster than the 365hp saleen s281.........??????????
i thougt the saleen where at least faster than Ls1
Old Sep 23, 2002 | 06:31 AM
  #69
Nic's Avatar
Nic
Engine: 5.0L
In head to head testing between the Roush Stage 3 and S281, the Roush ran 12.83 @ 107 and the S281 ran 12.92 @ 105 on street tires. They put slicks on the S281 after that and ran 12.70.
ndndndnd
Sep 28, 2015 08:00 AM
-=Z28=-
Sep 24, 2015 10:21 AM
okfoz
Sep 22, 2015 03:37 PM
Thirdgen89GTA
Sep 12, 2015 08:39 PM
