4.3 Blazer
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
4.3 Blazer
Okay, I know that things have slowed down some here, but I actually got into a race the other night in my 85 T/A. I was comming home from work, and when I got on the last major road, HWY 62, I see this black newer Blazer 2 door, 2 wheel drive, that had been lowered, run the redlight that I was stopped at. He was turning across traffic, the direction that I was going. I thought to myself, well if I catch him, I'll see if he wants to race. About a mile from my turn, he is right in front of me, and I see him tap his breaks and then take off. I let him go twice, then I got right beside him just before my turn, and figured, why not....I kept going straight. I was next to him, and we slowed to about 50, then he hit it. The car downshifted into 2nd, as he was a fender infront of me. It didn't take me long to catch him, and at about 80, his front tire was by my back tire, and he gave up.
I backed out of it, and turned around to go home, with the knowledge that he had been taught that his Blazer wasn't as fast as he thought.
I backed out of it, and turned around to go home, with the knowledge that he had been taught that his Blazer wasn't as fast as he thought. Thread Starter
Car: 85 Trans Am
Engine: LB9
Car Type
The car is an 85 T/A. It's an LB9 auto that's bone stock (not even an exhaust). She's quick enough, for now......
Car: 1990 IROC
Transmission: TH700-R4
Originally posted by curt86iroc
nice car. yea, the 85 LB9's had the larger cam. they run very good times for stock 305's...
Car: 1990 IROC
well, the LG4 is a carbed 305 for starters. it was the base engine for all z28 camaros and irocs until it was replaced by the L03 305 (TBI) in 88. The LB9 (TPI 305) came out in 85. it produced 215 hp this year in both manual and auto form due to the larger cam, which is the same cam used in L98 equipped cars. in 86, the LB9 got the peanut cam, which reduced its hp output to 190. once the g92 option became available on the LB9 t5 combo, its hp rose up to 215 again.
Car: 1990 IROC
nope, its the opposite. carbs have much more of an advantage over TBI. TBI really has to aftermarket and the LG4 is easier to work on than an LO3.
I raced an older blazer (pre 94 style) once on the freeway in my 90 RS with a L03. We started at like 65mph and I got passed at around 95mph. I was like
I later found out the blazer had a LT1 swap. Pretty cool!!
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
Originally posted by devianb
If that is the case, whey would they make TBI engines instead of just carbed ones?
) TBI belongs in trucks not performance cars. Supreme Member
I know this is really off topic, but what are the major differences betweeen EFI, TPI, MPFI, and Cross Fire Injection? Fuel is one are I know the least about.
Car: 1990 IROC
well, EFI is a broad term that refers to all types of electronic fuel injection. in fact, thats what it stands for. TPI is a batch fire dry manifold system. all injectors on one side fire at the same time. TPI just means that the runners are tuned for a certain RPM range. SFI is what the LT1's and the LS1's use. this is where the injectors are placed behind the intake valves and spray independently whenever the intake valve opens. im not sure exactly how MPFI works, but its some kind of EFI. Cross fire injection is kinda like 2 TBI's arranged diagonally on an intake manifold, except the one on the left feeds the right side and the one on the right feeds the left side. it really was the worst induction system ever. it was stopped after 2 years because of all the problems with it, especially starting in the cold.
Thanks again curt86iroc. Now I know a little bit about the different fuel delivery systems. I'm glad no one mad fun of me. Now to get back on topic, great job tackeling that new Blazer. This one more point for old school.
Car: 1990 IROC
ps. no one should make fun of you. we're all hear to learn.
lt1z350
Sep 29, 2015 01:50 PM
