Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Loss to V-Tec - Advice for next run:
Old Dec 16, 2003 | 12:23 AM
DeathDealer's Avatar
Car: 1992 RS Camaro
Engine: 5.0 L03 TBI 305
Thirdgenners:
After work tonight I decided to race my co workers Civic equiped with a V-Tec and Manual Transmissions (no mods). Lost both times by about 2 car lengths (maybe a 1/8 mile). I expected to lose but I was hoping it would have been a little closer. I think V-Tecs run low 15's right? I want to race him again soon. What should I do to make it little closer? I can't really afford any mods right now. I'm alittle strapped for cash. Any Advice?
DD
'92 RS
305 L03
700R4 Auto
K&N filter
Old Dec 16, 2003 | 12:29 AM
3rdGenBlackBird's Avatar
Race from a stop, and practice launching. Take out your spare tire and any tools next time, and uncap your exhaust. If you don't go any quicker, you'll at least sound meaner.
Laters.
Old Dec 16, 2003 | 12:33 AM
Car: 1992 RS Camaro
What do you mean "uncap your exhaust?"
DD
Old Dec 16, 2003 | 01:17 AM
fyrechikyn's Avatar
try the ultimate tbi mods their free and like blackbird said shed as much weight as you can.
Old Dec 16, 2003 | 07:31 AM
cas0484's Avatar
Car: 1994 25th Anniversary Trans Am
Engine: Lt1
Transmission: A4
Was the civic an Si? Because that's the only way I could see you losing. Try racing from a stop, the lo3 may not be a powerhouse but it should be able to dominate a stock civic off the line. You out torque him like crazy!
Old Dec 16, 2003 | 08:44 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Ya if it was an Ex civic, even with a five speed you should have nailed him good as the EX got a single overhead cam v-tech engine good for about 127hp at the crank. My rs, that is pretty much stock (chip from tbichips.com and a k&n don't really count as mods, just treats for the car), and i waste em from a stop and roll pretty regularly. I drove my roommates '00 EX auto yesterday and while they feel very quick, that is about it, they FEEL quick. An SI though, is unfortunatly, a differant story for us L03 owners.
Old Dec 16, 2003 | 04:02 PM
Car: 1992 RS Camaro
Ya, its a DX.
So... Your all saying I should have smoked him? What am I doing wrong?
DD
Old Dec 16, 2003 | 04:26 PM
Nitrous Al's Avatar
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Go to the TBI forum for some tips. Someone should be able to help you. Save up your money and put a 350 on your wish list for Santa.
Old Dec 16, 2003 | 05:12 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
either he can drive well and you cant. or your gonna have to do some cheap mods. for about 100.00 you can get a shift kit that would help alot. new air filter replace your tranny fluid oil oil filter basic stuff. take out all your weight like was said. take some air out of your tires it will help you launch
Old Dec 16, 2003 | 05:41 PM
Car: 1992 RS Camaro
What advice can you give me for being a better driver? Can someone list out the fundementals of launching, auto shifting, ect?
DD
Old Dec 16, 2003 | 10:51 PM
A88GTANotchback's Avatar
its probably not the best for the car but u can put on the brake rev it until u feel the tires wil break loose if u rev any higher and let it go. dont spin hard off the line. manual shift it (not often). and rev to about 4500 to 5000 then shift.
Old Dec 16, 2003 | 11:22 PM
Jokerman's Avatar
I would first put the money into a good tune up because a Dx is even slower than an Ex and for you to lose to either means there are some issues. Do a good full tune up, (cap, rotor, wires, plugs, oil and filter, fuel filter, check the timing, change your coolent, check your belts, check out your U-joints, check and/or change your tranny fluid and filter, and check your egr shyte) then run him again. You shouldn't have a problem with em unless there has been some decent work done to the civic. Then start going for the mods.
Old Dec 17, 2003 | 12:17 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Bump up your timing...When it starts to ping, back it off about 2 deg. If you're worried about detonation, Run alittle higher octane. Inflate your front tires to max psi and let the rear tires down a bit. Sounds like you're spinning too much off the line, roll your foot in the accelerator, try not to let the tires break loose at all. Shift manually starting at first, as you feel the power(torque) fall off, bump to second and Just BEFORE the power falls off, pop it into Drive. NEVER "stomp" the accelerator....Roll it, let the torque pull you, when you stop feeling it, he's gaining on you. a VTEC should be no match for you (prelude VTECS excluded...unfortunately)
Old Dec 17, 2003 | 10:18 AM
Car: 1992 RS Camaro
Thanx for everyones responses so far. But one quick question Fbodtrek, What is bumping up your timing and what does it do?
I think I'm gonna wait for a sunny dry day and take a freind out to one of my race spots with a stop watch and work on my launching.
Old Dec 17, 2003 | 10:20 AM
Car: 1992 RS Camaro
Oh and as far as Octane, that shouldn't be an issue, I always run 93 and most of the time pun 5-10% Xylene in it (not for power, because as we all know, octane booster doesn't do it) but to help clean out my motor a bit (124000 miles)
Old Dec 17, 2003 | 08:12 PM
FbodTrek's Avatar
Octane
The 93 isn't doing ANYTYHING for power. The only reason it should be used is A: if you're running high compression (10:1+ and even then you can run regular with the proper timing...) B: if you're running a blower/turbo C: If you're spraying. Bumping the timing is Advancing it, more advancement can help you or hurt you, One way it could hurt is causing premature detonation (BAAAD). It could help you though, when the timing is Advanced, it delivers the spark to the cylinder sooner, you want it to detonate Just right to develop the most power. As far as preference, depends on what your car likes....If I were you I'd take it to the local Tuner and tell them to tune it for Dragging, they SHOULD know what to do. Don't try advancing it yourself if you don't know what you're doing, you would prolly skrew somthing up. Good luk, and don't let the Hondas get you down...
Old Dec 19, 2003 | 07:12 PM
Nitrous Al's Avatar
Transmission: AOD
I don't think his Civic is stock. What year did the Civic get the B18A motor? Smells like a B18 motor swap.
Old Dec 19, 2003 | 08:14 PM
Car: 1992 RS Camaro
Its a very weird run...
One guy at work said that it had exhaust, intake, intake manifold, and a clutch.
Other guy said everything was stock to give it a 'sleeper' look and it actually had twin turbos
Of course, the driver said it was stock
Regardless, I'm gonna do some more looking into it.
DD
Old Dec 20, 2003 | 12:13 PM
91gta_tpi's Avatar
Car: 91 GTA
Yeah it had to have some work done to it, because my friend's mom has a stock 2000 Pontiac Sunfire, with a 2.2 liter OHC engine, and we can absolutely murder even B18's off the line, but if the guy is claiming it is just a stock DX, then you should have handed his a** to him tremendously, unless like everyone else said, it was an SI, but I still think you could take him off the line.
Old Dec 20, 2003 | 01:31 PM
Nitrous Al's Avatar
Transmission: AOD
This is an underhood picture of a Civic with a naturally aspirated VTEC motor swapped in.
Attached Thumbnails Loss to V-Tec - Advice for next run:-civic.jpg
Old Dec 20, 2003 | 01:34 PM
Nitrous Al's Avatar
Transmission: AOD
This is an underhood pic of a Civic with a VTEC motor swapped in with a turbocharger. Look at both pics and try to find out with motor he has in his car. Stock on the outside and modded on the inside. It's good you didn't run him for money.
Attached Thumbnails Loss to V-Tec - Advice for next run:-civic-vtec.jpg
Old Dec 21, 2003 | 01:43 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
sell it, your car has problems
Old Dec 21, 2003 | 03:11 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: Loss to V-Tec - Advice for next run:
Originally posted by DeathDealer
Thirdgenners:
DD
'92 RS
305 L03
700R4 Auto
K&N filter
Remember, "how fast you want to go depends on how much money you have to spend" (and to a more importantly WHERE and WHAT you spend it on), but with free mods and what you have to work with (no cash), overcomming a 2 car deficit is going to be tough, especially if you've run a couple of times and it's been similair on both runs.
Ya, ripping all the weight you possibly can out of the car may help (get some wait off the front and more to the back), tire pressure, launch, advanced timing, and shifting (although manually shifting that 700R4 is for cheeseballs) are things you should work on. Have you gutted the air box??
Things like these can help, you might make up a car or two, but is it enough to be ahead?? Tough call.
Old Dec 22, 2003 | 03:38 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Well, since you said it was a "co-worker" you raced, I imagine you do have some source of income, but if I remember my high school days correctly, the term "income" you should used with caution.
First things, you said you have a K&N element. Is that just a stock replacement or an open element? I suggest you dump the stock air filter housing and go with an open element. $45 tops.
2.) Do a good tune up on your ride. MSD wires or some of those Accel 800+, AC Delco Rapid fire plugs gapped at .045, MSD blaster coil and a new cap and rotor. $100 tops for all of this and it could even be less if you go with some Bosch wires.
3.) As suggested, bump up your timing. (OR HAVE SOMEONE HELP YOU WHO'S DONE IT BEFORE) There's a certain wire you have to unplug before you do it, so the computer won't make adjustments counter-acting your work. There's an article on advancing the timing in the tech articles. Most of our TBI's like about 6 - 8* of advance. FREE
After all of this, there is absolutely NO REASON why you should lose to DX's and EX's. Hell, I'm surprised you lost to begin with.
And as for the practicing your launching with a buddy, forget about it. A stop watch is not accurate at all for that kind of measurements. Simple powerbrake while in Drive to about 3000 rpms and release the brake pedal when it's time to go.
Old Dec 22, 2003 | 11:02 AM
Car: 1992 RS Camaro
Thanks for all your responses guys. I work later tonight and I'm gonna look more into the 'stock or not stock.' Thanks for all the advice on upgrades for a poor guy With Christmas, and a few car repairs that need to get done, its a bit tight lately.
DD
Old Dec 22, 2003 | 08:05 PM
FbodTrek's Avatar
Manually shifting the 700r4
I wouldn't say its for cheeseballs, BUT I can see what you mean. Automatic don't ALWAYS take advantage of the powercurve . My v6 has an INCREDIBLY short first gear (like starting in 2nd). Manually shifting is the only way I can grab that Higher RPM power (if thats what its even called in a six....) Don't just assume that the auto is doing its job unless it's fresh or has a shiftkit.
Old Dec 23, 2003 | 05:17 PM
Car: 1992 RS Camaro
I talked to one of his friends (another co-worker) and apparently it has a Si Motor He did say that it is stock from the factory, is this right? Did the DX's ever come with the Civic Si motor? If so, is the 2 car length loss about right or what?
DD
Old Dec 23, 2003 | 07:09 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
What year in this Civic we are talkin' about? Weren't "DX" models available, like b/n '87-'92 Civic's?? If I am correct the DX model was the base Civic and did not include the Si motor.....
Old Dec 24, 2003 | 12:20 AM
Jokerman's Avatar
That would be crap, pure and simple crap. The DX never came with anything more than the current models 115hp 1.7 liter non vtech motor. from the early 90's on up to like 01 they got a whopping 106hp. No options, not dealer specials, nothin. Its either a motor swap, a badging swap, bone stock, or a modded stock engine.
Old Dec 24, 2003 | 01:02 PM
Car: 1992 RS Camaro
I talked to my coworker today. I guess I violated the first rule of street racing, 'Know your enemy.' I was told by a few others that it was a DX but it's actually a Si. I did enjoy the discussion here though, When it gets a little nicer out I'll work on some of the free mods listed to help out a bit.
...But anyways, back to racing.... I lost by about 2-2 1/2 car lengths at about almost 1/8 mile. Is this about right? Should it be a touch closer?
DD
Old Dec 24, 2003 | 02:38 PM
Nitrous Al's Avatar
Transmission: AOD
This is a pic of a '00 Civic Si. The owner told me it's a 1.6 four cylinder, but I know it's a 1.8L DOHC VTEC motor (B18). Does your coworker's car have this motor or something else with a "smaller valve cover"? When you look under the hood, look between the motor and the grille, at the exhaust manifold. You'll be able to tell if he's running a stock manifold or tubular header and/or turbo. Import guys love to tell people they beat a V8 car in a drag race. You got to beat this guy!!!
If you apply this same knowledge, he won't be able to tell the difference between your stock 305 or a nasty 383. If he beat you by only about two cars, it's time to figure out your combo so you can beat him in the spring. I don't know if the L31 Vortec heads can help you, but you can pick up a pair for around $520. Post a message in the TBI forum about increasing the TBI's horsepower and torque.
Old Dec 24, 2003 | 02:40 PM
Nitrous Al's Avatar
Transmission: AOD
I forgot to attach the pic.
Attached Thumbnails Loss to V-Tec - Advice for next run:-civic-vtec2.jpg
Old Dec 24, 2003 | 03:13 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
How To Launch
Its actually incredibly simple. (feel free to skip my little intro but im just putting it in to give you an idea of what im saying)
You ever notice when driving your car how at one speed, you'll floor it but wont go to fast or it will take your car awhile to really start moving, while at other speeds you floor it and your car is just instantly at full power and you just zoom on? Its all about what RPM's your at.
I'll use my escort for example ... at 2k if i floor it it goes but takes awhile to get moving. now if i wind the motor up to 3k and let it go it kicks back and shoots off... well shoots off for an escort
Heres how to launch (if im wrong somewhere feel free to correct me anyone)
Im assuming you have an auto sooooo
1. put it in first gear
2. hold the brake with one foot and use the other for gas like your about to do a burnout.
3. this is where you load the converter... hold the brake and rev to about 1900 or so... im not sure with tbi but id say thats a good rpm?
4. when its time to go release brake and mash gas
Old Dec 24, 2003 | 03:21 PM
Nitrous Al's Avatar
Transmission: AOD
Great info, but he has to identify the motor in the car he's racing. His co-worker might have a BMW V12 motor in that thing...LOL and DeathDealer doesn't know it. No offense, DeathDealer.
Old Dec 24, 2003 | 03:31 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
Attached Thumbnails Loss to V-Tec - Advice for next run:-butthead.gif
Old Dec 24, 2003 | 03:43 PM
Nitrous Al's Avatar
Transmission: AOD
Hopefully he's not racing Stephan Papadakis' mid 6 second, 200 plus mph Civic.
Attached Thumbnails Loss to V-Tec - Advice for next run:-civic2.jpg
Old Dec 24, 2003 | 07:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well since you said your car is stock. First you need to take full advantage of all the power your setup can produce. I'll assume your car is dog crap off the line since a stock honda dusted your butt. Lemme guess you can be crusing in 3rd 30MPH floor it and it goes like no other??????? High on your list of mods should be a drop in V6 3:42 differential. This will allow your to use the power you have down low where you need it. A high numericaly low gear set like your stock (2:73's, 90%) or 3:08's is nice for crusing down the interstate a low RPM's but thats about all. So for a couple hundred bucks and an afternoon you can improve your acceleration from GEO metro to what it should be, **** planting tire burning. Exhuast works quite well too, but id focus on gears first, A dual snorkle induction setup will pull almost as much air as an open eliment but has the advantage of being cooler then the engine compartment air. Ive seen it broken down as far as for every 10* drop in temp is 1hp.
Old Dec 25, 2003 | 08:18 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
death dealer...
a little help for you to first determine what the model of the car is... when you see it next..look at the brakes... if it is 4 wheel disc..welcome to the world of si/sir as well look for a stb (strut tower brace) and if thats the case with your stock tbi..you aint got a chance in hell to win, but if it has drums on it..take a peek on the inside...does he have any power options? (windows locks) cuz NO dxs got power options...it was noted that these were the botton end of honda civics so thats that..
as for you winning...depending on the car is what is gonna have to be done...
si/sir get a bigger block, that motor just aint gonna cut it... ex or dx or even cx.. do the free mods and do what the others have said (tune up and such) and you shouldnt have a problem...
or..get one of the guys from this board to come and race...and then..watch his face when he cries hehhe
iroc2nv
Old Dec 28, 2003 | 01:54 PM
zerotosixtyV8's Avatar
Car: Camaro
the best vtec anything runs mid 15s. civic = mid 16s. tune your car up and run from a dig, you should destroy him. if that doesn't work, 100 shot
Old Jan 14, 2004 | 11:52 PM
NewGuy00's Avatar
Sorry dude, the Civic SI comes with 1.6 LITER ENGINE. The pic you show here is a 1.6L because I can tell from the intake manifold. They are mid 15 sec cars around 87 bone stock. The best I could ring out of mine bone stock was a 15.701 @ 88.93. In most cases I was around 15.85. No DOHC motors are mid 16 secs, the civic EX also a 1.6L SOHC is a solid (lol) mid 16 sec car. Yes all civics are slow blah blah blah. I know I know I know.
Old Jan 15, 2004 | 03:46 PM
Nitrous Al's Avatar
Transmission: AOD
Thanks for the info, NewGuy00.
RedLeader289
May 28, 2019 01:47 PM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
