Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Me vs modded LS1
Old 02-03-2004, 11:38 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Me vs modded LS1
Curious who you guys think will win. Race will likely happen friday night if my friend gets the car.
My Car:
350HO crate motor, headwork, 10:1 compression, XE274 camshaft, hughes 3000 stall, th350, 3.73's
His car:
98 LS1: headwork, lid, injectors, headers, exhaust, m6
Curious who you guys think will win. We will be racing from a stop and from a roll.
Old 02-03-2004, 11:46 PM
25THRSS's Avatar
does he have a cam, and why did he get injectors?
Old 02-04-2004, 12:09 AM
He is purchasing the car, wasnt him that modded it. An older cop owned it before him. I think its some innate old man thing that a car has to have a chip and bigger injectors if it is fuel injected to make good power. Not sure if it has a cam, I dont see why it would have head work if it doesnt have a cam, but maybe the guy was a bonejob.
Old 02-04-2004, 12:17 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i think he would win just because he has more things than you. a 350 ho is only 330 stock but with the cam and depending on your head work maybe 350 tops. since he has 325 starting and has headwork lid and exhaust done i think he has you beat is he a 6 or an auto if its a 6 and he can drive he has bus lengths. i think either way you lose
Old 02-04-2004, 12:35 AM
My car runs 12.4's at 110 on street tires, would go 12.2's or 12.1X's on a sticky tire. It makes more than 350 horsepower.
Old 02-04-2004, 12:56 AM
25THRSS's Avatar
I think it'll be close, but if he has a descent cam and the car is in tune he will get you assuming he can drive it.
EDIT: from a roll you are definitely toast, but from a stop you may be able to hang assuming the above.
Old 02-04-2004, 02:09 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I think you have him all the way.
Old 02-04-2004, 03:20 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
by the looks of ur 1/4 mile time, it might be real close but i think u will win. but if he has a good tune on his ls1, he might get u on top end
Old 02-04-2004, 07:04 AM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I agree with 25th, the LS1s are killer up top. My friends 2000 was running 110 traps with and exhaust and lid (he might have had 4.11s). I think if you hook to 12.4s @ 110 on street tires race from a stop, not from a roll.
Old 02-04-2004, 07:34 AM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
It depeneds what kind of "headwork" this car has. I just don't see any reason why anyone would put new injectors in a pretty stock car, even with "head work". I'm thinking the head work means stock heads.
Basically, if someone bothered to mess with the heads, it more than likely has a cam, has been tuned, etc... It should run 11's with heads/cam. He'll get you up top no matter what, heads or not.
I went almost 112 with just a lid, catback, and drag radials. They are super easy to get power out of.
Old 02-04-2004, 12:17 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
you'll win because he won't have any seat time in the car.
its hard to buy a car one day, and then cut an awsome 1/4 in it the next day without any previous racing experence in the car.
Old 02-04-2004, 02:43 PM
Marc 85Z28's Avatar
Re: Me vs modded LS1
As long as you have decent tires, aka cheaters or DR's, I would run him from a stop and forget about it. I rarely see decently powered high stall auto cars get taken by a manual car from a stop. Even though he should be trapping similarly to your car, he won't be able to catch up after you put several lenghts on him at the start. But with the M6, a roll it dangerous, especially with a bolt-on LS1. He'll be in his powerband from the go, will you?
Old 02-04-2004, 03:44 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
I think you got him from a stop...but from a rolll.. I think your going down. What you need to do is put a 50 shot on there, and after you hook up, spray it.
Old 02-04-2004, 05:53 PM
I have an NOS cheater kit but I wont be using it for that race.
Old 02-04-2004, 06:21 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
I think depending how you hook up, will see how much you'll bet him by if at all.
for sure a good race n let us know how it goes
Old 02-04-2004, 06:26 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
That should be an awesome race, any chance of getting it on video (in car prefferably)???
What does your "headwork" consist of, any porting or just spring work to support the 274 cam? I'm pegging you at 425hp MAX with some porting, 400ish if not, if he indeed has ported heads and a hot cam with longtubes and such I think he will have the power advantage by a bit. But then your car sounds more heavily setup for a 1/4 run, and he will have some driving issues too even if he is a good stick driver IMO. Will sure be interesting to see who wins...
Old 02-04-2004, 07:21 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
I say you by atleast a car.........Like stated above, he has no seat time.
Old 02-07-2004, 08:49 AM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
So...did the race go down?
Old 02-07-2004, 09:59 AM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
yes we would like to know!
Old 02-07-2004, 10:41 AM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Going to be a good one. Depending on his launch and shifting abilities, he should have you. But if he can't do that, you might end up on top.
LS1's are strange beasts. We have completely stock engines around here but every bolt on you can think of running 11.5-11.8. They are very impressive to say the least!
Old 02-07-2004, 10:46 AM
PhoenixFB350's Avatar
yeah, he would have no idea where to shift it, what its powerband is, or how to launch it. of course if hes a good driver he'll figure it out within a run or two so watch out cause those kinds of cars (with those mods) should run 11s. how did you do?
Old 02-07-2004, 05:02 PM
Well the race isnt gonna happen . He is 19 and found out insurance will be $408 a month due to previous tickets
I really wanted this race to happen. I have driven a stock down to the paper air filter 98 B4C LS1 A4 with 2.73's. It felt good from about 4700 on up, but didnt have a lot of low end torque. I have driven numerically low geared cars with good torque (my car before I switched to 3.73's) and it didnt feel like my car used to in the torque department, pretty weak. Even from a roll it didnt feel like it had a lot down low. I took the kid for a ride in my car right afterward and he was really impressed, wanted to know how he could make his car (98 B4C) feel like mine, so it was more than just opinion.
I think I would have put 4 or 5 car lengths on him by the 330 foot due to new driver error and me making more torque and being better in the my power band the way the car is setup, and then he would have had to try to reel me back in if the car had even been modded properly. My car traps a hair over 110 and is in good tune, my thinking was I would have him based on what I gained down low.
I need to find another LS1 around town to race .
dusterbd
09-29-2015 08:40 AM
Quick Reply: Me vs modded LS1
